» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 11-24-2006, 12:55 PM   #1 (permalink)
Date registered: Nov 2006
Vehicle: 1992 400E, 1995 E420
Climate control 1995 420E
I just got this 1995 E420 and there are a few things wrong. The Blower moter only runs on slow. I have checked the fuse F15 and it is good. I have changed out the climate control module with no improvement (part from used car ????) I was trying to check everything else before I go at the blower motor and blower module. I can access the plug X64 in back of the brake booster. Now my question is what signal is coming from the control module N22? Is it a 0-12V signal or a resistance? I can connect the battery to pin 2 and ground pin 1. If I could control the signal on pin 3, I could tell quickly if I need to remove the wiper and motor, or if the problem is in the wiring.
Glenn S is offline   Reply With Quote
Old 11-24-2006, 07:29 PM   #2 (permalink)
sunman's Avatar
Vehicle: 2003 C320 Sedan, 1992 400e sedan
Send a message via AIM to sunman
It's probably the blower regulator located in the blower motor area. Very common to go bad. You'll have to remove your wiper assy to get to it.
2003 c320 Sedan - Completely updated to 2005 spec with all euro and usa options
2002 s500 Sedan - Completely updated to 2006 spec with all USA options and some euro options.
http://web.mac.com/motorwerks
sunman is offline   Reply With Quote
Old 11-25-2006, 09:02 AM   #3 (permalink)
Thanks for the reply sunman/
It probably is the blower controler. I was just trying to check out as much as posible before I pulled the blower. With my luck after I have everything apart, it would turn out to be something like a wire gone bad between the climate control and the controler.
Old 11-28-2006, 07:39 PM   #4 (permalink)
macdrone's Avatar
Vehicle: 1993 400E 222111 miles "Gunter", 1999 ML320 187000 miles "Fizgig"
First try the 30 amp strip fuses by the fuse box. Then try the climate control fuses in the fuse box (replace all aluminum fuses with copper).
macdrone is offline   Reply With Quote
Old 11-29-2006, 05:37 AM   #5 (permalink)
I checked the 30 amp strip fuse, it was good. The climate control module had light and the blower moter did work on low. I can hear the damper valves operating when I change control setings. I will check the climate control fuse but I think its OK to. I have a 400E for a parts car. I am going to remove the blower motor and regulator for practice and posibly parts before I tare into my running 420E. What I wanted to know was if I removed the plug from the blower regulator and applied power and ground to the two terminals, what do I apply to the terminal coming from the climate control ? It's eather a resistance to ground or a voltage 0-12V.
For sale 1995 C280 Climate control Cataplas For Sale/Wanted/Trade/Giveaway 0 11-03-2006 02:08 PM
To go fast - 400e or 420e? POS W124 E,CE,D,TD Class 4 05-04-2006 01:29 PM
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 09:51 PM
1995 E320 climate control help pblank General Mercedes-Benz 3 07-12-2005 04:34 PM
1995 E320 climate control pblank W124 E,CE,D,TD Class 1 07-08-2005 04:52 AM
