Old 11-14-2006, 04:18 PM   #1 (permalink)
Date registered: Nov 2006
1994 Mercedes-benz E320
Hi there,
I am considering buying a 1994 MERCEDES-BENZ E320 from a friend. The car is in very good condition, used as a family car with low mileage (150,000 km).
It does have minimal rust on the body (mostly around fender/tire) and the mechanic recommends doing another paint job..
Wondering if I should consider buying it due to the rust and if there will be any major maintenance problems to consider…Also, what would be a good price?
Thanks,
Roger
adventurer4u2 is offline   Reply With Quote
Old 11-14-2006, 04:47 PM   #2 (permalink)
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2000 C230K and 2002 ML320
couple things... where are you located and has the wirning harness been replaced? That right there is around $1,000 USD
2000 C230K -- Travertine Beige Metallic
2002 ML320 -- Alabaster White
2002 ML320 -- Brilliant Silver - Dad's
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
'91 300CE is offline   Reply With Quote
Old 11-14-2006, 09:05 PM   #3 (permalink)
battlecat714's Avatar
Date registered: Sep 2005
Vehicle: 1994 040 E500
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
what is that like, 91k miles? not bad, your probably looking at $5500-6500 USD.
battlecat714 is offline   Reply With Quote
Old 11-15-2006, 03:47 PM   #4 (permalink)
Thanks Jorge
Old 11-15-2006, 03:47 PM   #5 (permalink)
Hi there,
I am located in Toronto and have no idea about the wiring harness..
Cheers
Old 11-15-2006, 05:36 PM   #6 (permalink)
oOoOo you're in for a ride
Old 11-15-2006, 06:15 PM   #7 (permalink)
autoworrks320's Avatar
Date registered: Sep 2006
adventure I am in toronto and could give some advice on the car. pm me.
autoworrks320 is offline   Reply With Quote
Old 11-15-2006, 06:19 PM   #8 (permalink)
janos_z's Avatar
Vehicle: 1989 560 SEL, 1994 E320 wagon, 2007 C230
rust and paintjob are expensive too. '94 E320s are not too rare, so i would hold out for a non-rusty one.
Janos
Current:
-1989 560SEL
Past:
-2007 C230
-1994 E320 wagon
-1993 400E
janos_z is offline   Reply With Quote
Old 11-15-2006, 10:22 PM   #9 (permalink)
vili1982's Avatar
Date registered: Jan 2005
Vehicle: 95 E320 Coupe, Diesel Golf
Send a message via MSN to vili1982
yes, but if he is picking up the car from a friend I'm sure he will give him a good deal, and at 150 k's that car is on it's way to the harness issue any day now along with many other electircal problems, unless everything was maintained on time by the previous owners then you just may pick up your self a good deal.
btw:I'm about an hour away from you, welcome to benzworld.
In the world of roads, there are those who travel and those who own it. The choice is yours.
95 Coupe
vili1982 is offline   Reply With Quote
Old 11-16-2006, 07:47 PM   #10 (permalink)
94Wagenmeister's Avatar
Date registered: May 2005
Send a message via AIM to 94Wagenmeister
I just had a nice looking 94 up on the lift before offering. Good thing too as it was cosmetically perfect (and drove ok). What we found it needs or will soon:
motor mounts
axel mounts
right side tie rod
drive train flex discs
We stopped looking after that. goes to show you that even the most "perfectly maintained" E320 is going to have expensive wear issues after 12-13 years.
Caveat emptor!
Scott in MD/DC
94 E320 Wagon (Just getting broken in)
95 C280 (RIP)
87 190E (Sold)
"There is nothing more expensive than a cheap Mercedes"
94Wagenmeister is offline   Reply With Quote
1st TIME Mercedes-Benz owner! ISO Advice (1994 E320) TMaticE320 W124 E,CE,D,TD Class 12 04-28-2006 07:41 AM
1994 mercedes e320 wiring harness JChora7 W124 E,CE,D,TD Class 1 05-03-2005 06:48 AM
1994 mercedes e320 wiring harness JChora7 W124 E,CE,D,TD Class 3 05-01-2005 07:35 PM
1994 E320 - Is original Mercedes radio better than Alpine? pjtv Audio & Telematics Forum 1 07-10-2004 11:11 AM
Body kit for a 1994 E320, modified benz Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 11-29-2001 05:42 PM
