Old 11-11-2006, 01:55 PM   #11 (permalink)
battlecat714's Avatar
Date registered: Sep 2005
Vehicle: 1994 040 E500
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
oh wow...that car is freegan clean.
battlecat714 is offline   Reply With Quote
Old 11-11-2006, 02:08 PM   #12 (permalink)
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2000 C230K and 2002 ML320
Yes it is extremely clean!!! I love it... and I love the fact that you have a 911 as well... my 2 favorite things in life...
2000 C230K -- Travertine Beige Metallic
2002 ML320 -- Alabaster White
2002 ML320 -- Brilliant Silver - Dad's
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
'91 300CE is offline   Reply With Quote
Old 11-12-2006, 03:59 PM   #13 (permalink)
Date registered: Oct 2004
Vehicle: 94 E420
Ok I've paid more attention to this over the weekend and have discovered that the engine runs smooth when cold. Only once it warms up does it miss?
tonyp1 is offline   Reply With Quote
Old 11-12-2006, 09:55 PM   #14 (permalink)
Date registered: Feb 2004
Vehicle: 68 280 SEL, 89 300TE
Send a message via AIM to myfirstbenz Send a message via MSN to myfirstbenz
Exclamation
If you haven't checked to make sure that the plugs and wires are free from corrosion like I mentioned earlier, I would next check the wires themselves. My 400E also had this problem, and it ended up being a bad wire. Pull off your air cleaner, when the engine is warm and idling/missing, and use insulated pliers to pull each plug wire at each plug one by one, connecting them back after each pulltest, that will tell you which plug is not getting juice, or if it doesn't affect your missing ignition, then you have problems elsewhere, but do the simple things first.
::Familie von Mercedes::
'00 German Sheperd ("Hans")
'89 300 TE 117k
'92 400E (killed in action)
'68 280 SE/8 (High School Sweetheart)
'95 E320 (mother's)
'60 190D (dad's new project)
'05 A6 Allroad 2.7t (dad's ride)
'84 190E (sold)
'90 300CE (brother's)
myfirstbenz is offline   Reply With Quote
AC runs 1 out of 20 engine starts gus1975 W202 C36 AMG, C43 AMG 0 07-26-2005 12:27 PM
Please Help, Engine bogs down & runs bad bcool R129 SL Class 9 11-03-2004 07:43 AM
Engine over heat after washed the car ? pc2074 W203 C-Class 0 02-26-2003 04:54 PM
Washed the engine now ...MUCH BETTER NOW ! Guest (MBNZ) W124 E,CE,D,TD Class 2 07-26-2002 04:10 AM
Washed the engine now ... Guest (MBNZ) W124 E,CE,D,TD Class 0 07-23-2002 04:28 AM
