Old 11-09-2006, 12:56 PM   #1 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
Tips for replacing front flex disc?
Hi,
I need to replace both flex discs this weekend. The rear should be straightforward. For the front one, is it necessary to loosen the big (41 or 44mm) driveshaft nut or can it be removed by lowering the tranny a bit?
Thanks,
Sergio
'95 E320 180K miles
Sergio is offline   Reply With Quote
Front Flex Disc R&R Cheelyv W126 S,SE,SEC,SEL,SD,SDL Class 2 11-02-2006 07:44 AM
Front Flex Disc Replacement on a '95 E320 Sergio W124 E,CE,D,TD Class 2 02-24-2006 06:00 AM
Replacing Flex Disc?? W123madness W123 E,CE,D,CD,TD,TE Class 6 02-05-2006 09:07 PM
Help Replacing Rear Flex Disc on 420 SEL Inthemedia W126 S,SE,SEC,SEL,SD,SDL Class 2 06-02-2005 05:40 AM
300e front flex disc komik W124 E,CE,D,TD Class 0 10-26-2003 09:13 PM
