Old 11-08-2006, 01:08 PM   #1 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
How difficult is to remove/replace the tranny?
Hi folks,
I would like to know how difficult is to remove/replace the transmission in a '95 E320. I am a DIY with medium skill level. This would be done by myself and in my driveway (have jackstands and a 4 ton hydraulic jack).
I'm considering buying a rebuilt tranny and replacing it myself since most places will not do the job unless they provide the tranny.
My tranny is running fine but due to it's high mileage I have to start thinking in advance (I forsee a tranny swap within the next 30-40K miles).
Thanks,
Sergio
'95 E320 180K miles
Sergio is offline   Reply With Quote
Old 11-09-2006, 05:12 AM   #2 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
Sergio
I am thinking about the same thing , It seems pretty straight forward . The kicker is getting or making a transmission lift / jack ,to hold the 100 -150 lb box in position . I think you could rent one or use a low level motorcycle lift , shorten the pump handle / vertical frame ,,, $ 50 -60 for a chinese one.
Working on rough non level surfaces , can make a simple 10x more difficult.
While your in there, get the rear crank seal , maybe Eng. mount. I don't know how much exhaust system needs to come out , but having a torch - penetrating oil and a sawzall would be a plus .
If you have the transmission , even a small independent Benz garage could do it quickly. They will make their money on labor.
Uboater is offline   Reply With Quote
Old 11-09-2006, 05:24 AM   #3 (permalink)
Sergio's Avatar
Vehicle: 1995 E320
Thanks Uboater.
I think I will let the pros handle this one. When the time comes, I will call a couple of places and flat out tell them "I already bought the tranny, can you replace it" because if they know I haven't purchased it yet, they are going to try to talk me into having them supply it.
Sergio
replace front wheel bearing - how difficult is it? BenZ190D W201 190E, D-Class 12 04-04-2008 11:32 AM
How difficult is it to remove the gauge cluster? AMG NUZI W163 M-Class 7 11-07-2006 05:49 PM
How difficult is to replace the struts???? MBUSER W201 190E, D-Class 9 05-02-2006 02:49 AM
Re-seal Tranny or Replace with Rebuild? alexnatt W124 E,CE,D,TD Class 12 10-24-2005 08:45 AM
Don't replace that Tranny yet! wdba123190 W123 E,CE,D,CD,TD,TE Class 9 02-24-2004 03:30 PM
