Old 11-07-2006, 10:43 AM   #1 (permalink)
scoopcoupe's Avatar
Vehicle: E320 Coupe
E320 Key turn won't start - I need 2 go vote!
1994 E320
Car is in the garage right now, just spent half an hour going through 20 pages of search in the forum.
Went out to start the car for the first time today. Turned the key and everything lights up (as it should). Full electrical power, radio works, interior lights work, everything works. The only thing is that NOTHING is happening when pushing the key to the limit, in other words, turning it on. No crank, no sputter, no nothing.
Checked the fuse box, all looks good. Read about the OVP.. is that something that could be happening here? Like I mentioned, everything works, radio, lights, battery is fine.
It did this yesterday morning, but I thought nothing of it. Turned the key, and nothing happened. Thought "that's strange", then took the key out, put it back in, turned, and then it started right up. Drove around yesterday fine, starting and stopping, and now this.
I'm trying to get to my polling place so I can vote! Help! ;^)
scoopcoupe is offline   Reply With Quote
Old 11-07-2006, 11:22 AM   #2 (permalink)
sinyo's Avatar
Date registered: Sep 2002
Vehicle: c320 lorinser
maybe the starter?
sinyo is offline   Reply With Quote
Old 11-07-2006, 11:27 AM   #3 (permalink)
scoopcoupe's Avatar
Vehicle: E320 Coupe
not sure.... everything is powering on, just no kicking over, no choking, no nothing.
update.... it's not the starter, definitely. I remembered reading in the 20+ pages about a guy putting it in neutral and starting it that way.
tried to start it the normal way, made sure there was no steering wheel lock or anything, and the same thing--- power to everything, but no ignition. put the car in neutral, and it started right up! off to vote, but lets talk about this and figure what the issue is. came back in from the garage to post this.
Old 11-07-2006, 12:07 PM   #4 (permalink)
Sergio's Avatar
Vehicle: 1995 E320
You need to replace the neutral safety switch. Eventually it may fail to start in neutral as well.
Sergio
Sergio is offline   Reply With Quote
Old 11-07-2006, 09:29 PM   #5 (permalink)
vili1982's Avatar
Date registered: Jan 2005
Vehicle: 95 E320 Coupe, Diesel Golf
Send a message via MSN to vili1982
Either starter or what sergio said.
Or if you have an aftermarket alarm, sometime's if you lock the car with the remote and unlock it with the key, it wont start as a security feature incase someone was to steal the car.
In the world of roads, there are those who travel and those who own it. The choice is yours.
95 Coupe
vili1982 is offline   Reply With Quote
Old 11-08-2006, 04:36 AM   #6 (permalink)
Date registered: Nov 2003
Vehicle: 92-93 MB E320
neutral safety switch, if it cannot be crank in park, try in neutral
rvenerac is offline   Reply With Quote
Old 11-08-2006, 06:13 AM   #7 (permalink)
Date registered: Apr 2006
It can be the ignition switch faulty. I changed mine about six months ago. You can check it by supplying current directly to the solenoid switch at the starter.
bschan52 is offline   Reply With Quote
Old 11-08-2006, 09:49 AM   #8 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
What we have here is a giant right-wing conspiracy to keep you from voting.
flyboyike is offline   Reply With Quote
Old 11-09-2006, 09:07 AM   #9 (permalink)
scoopcoupe's Avatar
Vehicle: E320 Coupe
right-wing conspiracy? or left wing? ;^)
so I had no problems starting the car regularly on tuesday or yesterday. Can it be the starter? I can start it in neutral, but I haven't had to since my election day incident.
sergio & revener.....
What does the neutral saftey switch do? And if starting it IN neutral worked why does it need to be replaced. Don't quite understand.
vili1892...
No aftermarket alarm or starter kill of any kind.
bschan...
"by applying current to the solenoid switch at the starter" I've got the voltage reader... how exactly do I do that|?
Old 11-09-2006, 07:12 PM   #10 (permalink)
Date registered: Nov 2006
Vehicle: 1974 280C W114 / 1975 300D W115 / 1982 300SD W126 / 1981 VW Cabrio 16V
Originally Posted by scoopcoupe
1994 E320
Help! ;^)
This is the ATA (Anti Theft Alarm) starter lockout fuse. Check Fuse 5 in Main Fuse Panel # 1 for 1994 and up. For 1993 it is Fuse B.
toria is offline   Reply With Quote
turn the key and dash lights turn on, no power to starter bob richards General Mercedes-Benz 4 01-13-2006 07:48 AM
E320 turn signals work fine with key, dead with engine on Linc Fish W210 E-Class 0 08-01-2005 10:34 PM
TURN OUT THE VOTE FOR MORE ML's Ratso W163 M-Class 12 10-09-2003 03:49 PM
Key won't turn and ML won't start . . . acrafton W163 M-Class 6 02-09-2003 05:42 PM
Drew, to start an ('02) ML, simply turn the key and let go, right? MikeT W163 M-Class 16 12-14-2001 11:39 AM
