Old 11-03-2006, 05:06 AM   #11 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
You don't have to purchase MB parts to get the quality. But OEM which is exactly the same. Names like Lemfoerder, Febi, Boge, Sachs, Bilstein, etc are all acceptable. For struts I would go with Bilstein.
Sergio
Sergio is offline   Reply With Quote
Old 11-03-2006, 07:22 AM   #12 (permalink)
Date registered: Nov 2005
Vehicle: 300-SEL, 300-E
Send a message via AIM to Eric@StarSuzuki
I would also recommend Bilstein for the struts. The comforts are good. When I did Edwina's struts, I went with the Heavy Duty ones. Slightly firmer than the Bilsten Comforts, but not too harsh IMO. With the stock wheels and stock size tires, they are fine. If you're going with "upgraded" wheels (larger diameter, heavier) and tires (lower profile, heavier, ridiculous high speed rating), then the HD's might be a bit more annoying.
And neither the HD nor the comforts are really recommended if you lower the thing. For lowered applications, go with the Bilstein Sports, but be prepared for a very bumpy, harsh ride.
I used Febi mounts and Lemforder ball joints and control arm bushings when I did mine. No problems with OEM parts as far as my experience. I'd avoid the cheaper, 3rd world imports, though.
Eric@StarSuzuki.com
1990 300-E (Edwina)
1988 300-SEL (Gruselda)
1987 300-E (Eva)
1982 300-SD (Dumbledore) It'll take a wizard to get him running
1988 Mazda RX-7 GXL (Roxie) May she rest in pieces
Eric@StarSuzuki is offline   Reply With Quote
Old 12-19-2006, 02:26 AM   #13 (permalink)
Eric's Avatar
Vehicle: 89' 560SEL, 92' 300CE
Hey, never thanked everybody for all the help. Finally did the struts about 2 weeks ago. A lift and a jackstand was all I needed. Felt so good to finish that job. Thanks again and hope yall have a good holiday season. Aloha...
89'560SEL
92'300CE
Eric is offline   Reply With Quote
Front shocks WolfWinter W163 M-Class 1 03-22-2006 03:13 PM
R&R Front Shocks larryk R170 SLK Class 4 11-17-2005 12:56 PM
Front Shocks larryk R170 SLK Class 5 08-18-2005 06:06 AM
ML320 Front Shocks, and ML350 Front Shocks ranjitsml320 W163 M-Class 4 06-09-2005 06:23 PM
Front shocks gary1378 W163 M-Class 2 07-30-2004 12:48 PM
