» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 10-28-2006, 09:13 PM   #1 (permalink)
94Wagenmeister's Avatar
Date registered: May 2005
Send a message via AIM to 94Wagenmeister
Does the Antenna Mast Always Come Up ...
... when the head unit is on? Seems a waste for it to go up and down, up and down, up and down, all the time, especially when you're listening to CD's or cassettes. My 201 has a switch on the dash to keep it down. But the 124 doesn't?
Scott in MD/DC
94 E320 Wagon (Just getting broken in)
95 C280 (RIP)
87 190E (Sold)
"There is nothing more expensive than a cheap Mercedes"
94Wagenmeister is offline   Reply With Quote
Old 10-29-2006, 12:02 AM   #2 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
NO
I guess you could pull the power lead on a 124 antenna motor and just leave it up. I get annoyed when the antenna starts up ,when I roll the key on to raise the windows . I know you can turn off the radio , but that's just more work for a small job.
Uboater is offline   Reply With Quote
Old 10-29-2006, 04:32 AM   #3 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300TE x 2, 88 300E x2 (parts), 90 300TE 4Matic (parts)
So what year was *that* handy little antenna switch deleted? My 88s have it, including the wagon. Since most of my listening is to CDs I'm glad to give the antenna a rest. I find that even the satellite radio in the sedan works just fine with the antenna retracted all the way.
augapfel is offline   Reply With Quote
Old 10-29-2006, 08:01 PM   #4 (permalink)
So it's just a matter of time before it burns out then. Of all the over-engineered pieces on this wagon, that seems kind of short-sighted to me.
Old 10-30-2006, 12:51 AM   #5 (permalink)
kiasu's Avatar
Date registered: Feb 2006
Vehicle: 1989 260E
mine stays down when i play a cd and goes up when i switch to radio...probably because i have an aftermarket system.. sony cdx-m850, fs if anyones interested
if i can recall i think my becker audio deck did the same..
kiasu is offline   Reply With Quote
Old 10-30-2006, 11:17 AM   #6 (permalink)
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2000 C230K and 2002 ML320
Originally Posted by Uboater
NO
I use the key in the door to roll up my windows when thats all I need to do... no need to get in the car.
Just hold the key in the lock pos and the windows and roof close... hold in unlock and the windows roll down.
2000 C230K -- Desert Silver Metallic
2002 ML320 -- Alabaster White
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
2005 Porsche Cayenne S - Dad's
2004 Porsche 911 Turbo S
'91 300CE is offline   Reply With Quote
Old 10-30-2006, 11:21 AM   #7 (permalink)
Date registered: Mar 2006
Vehicle: 1991 Mercedes 300E
Send a message via MSN to pyro_la
i ran a new aftermaket one that sits on the rear dash, and then i shaved the stock one off. it looks alot cleaner now with same clarity and no more up and down or horrible ice buildup in the winter.
pyro_la is offline   Reply With Quote
Old 11-03-2006, 01:55 PM   #8 (permalink)
jcochrane007's Avatar
Vehicle: '95 E320
I put a new head unit in my '95 E320 recently. I connected the power antenna lead in the car's wiring harness to the appropriate wire on the head unit, and I thought everything was fine. When the radio was on, the antenna went up. When I put a CD in, the antenna went down. That was just what I wanted.
Then, I discovered that the door speakers weren't working when I played a CD. I pulled the unit back out and connected the power car's power antenna lead to the subwoofer power from the head unit and bingo, the door speakers work when playing a CD, but the antenna also stays up.
Conclusion: the powered door speakers and antenna run off of the same lead. You can't have one without the other. Bummer.
jcochrane007 is offline   Reply With Quote
Antenna Mast Mr2weenie W140 S-Class 1 01-18-2006 12:35 AM
Antenna Mast peter811 W123 E,CE,D,CD,TD,TE Class 2 12-04-2005 01:37 PM
Antenna Mast josephanthony For Sale, Trade & Wanted Items 2 04-29-2005 05:37 PM
Antenna mast not retracting ladybee W126 S,SE,SEC,SEL,SD,SDL Class 4 02-24-2005 04:48 PM
Antenna Mast garage bohemian W126 S,SE,SEC,SEL,SD,SDL Class 2 07-02-2003 02:03 AM
