Old 10-25-2006, 05:59 PM   #1 (permalink)
Date registered: Oct 2006
Exclamation Headgasket
Hello All,
I have a 94 E320 wagon with 135k on the clock, and i'm leaking oil! When a headgasket is replaced does the engine have to be removed?
Thx,
Dan
dcg451 is offline   Reply With Quote
Old 10-25-2006, 06:07 PM   #2 (permalink)
Date registered: Mar 2006
Vehicle: 1991 Mercedes 300E
Send a message via MSN to pyro_la
no just the head gets dissasembled.
pyro_la is offline   Reply With Quote
Old 10-25-2006, 06:27 PM   #3 (permalink)
augapfel's Avatar
Date registered: Jan 2006
Vehicle: 88 260E, 88 300E x 2, 88 300TE x 2
The answer to your question is no. The head is removed while the engine block remains in the car.
augapfel is offline   Reply With Quote
Old 10-25-2006, 06:41 PM   #4 (permalink)
How difficult is it to do the procedure, are there workshop manuals out there I can use?
Thx,
Dan
Old 10-25-2006, 07:28 PM   #5 (permalink)
flyboyike's Avatar
Date registered: May 2003
Vehicle: '79 280E
Originally Posted by dcg451
Hello All,
Thx,
Dan
Can you see where the leak is?
flyboyike is offline   Reply With Quote
Old 10-25-2006, 07:35 PM   #6 (permalink)
Yes, right rear block area of car
Thx, Dan
Old 10-25-2006, 07:46 PM   #7 (permalink)
flyboyike's Avatar
Vehicle: '79 280E
Thx, Dan
Could be the valve cover too.
How much should I pay for the headgasket? russoturristo W124 E,CE,D,TD Class 1 03-22-2006 05:48 AM
Headgasket done!!! Michael Pillay W126 S,SE,SEC,SEL,SD,SDL Class 5 08-18-2005 09:51 AM
w124 300e Headgasket. e_razor W124 E,CE,D,TD Class 4 01-06-2005 06:09 AM
Headgasket heckflosse W124 E,CE,D,TD Class 2 07-21-2003 04:54 PM
Blown headgasket!! Guest (MBNZ) Unimog 1 08-06-2000 07:51 PM
