Old 10-25-2006, 09:47 AM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 1993 Mercedes 300CE
'93 300CE Gas Leak Into the Trunk
Hi all,
i have a problem with gas getting out of my tank and getting into the trunk. It leaks somewhere underneath the tank i am assuming that will be the fuel strainer ring (i dont remember the name) coming out of the trunk going down to the pump. I had a lot of pressure in the tank itself and i think it caused the leak. i probably need to replace the tank vent valve.
Has anyone had a similar problem ??
Thanks for ur help
konrad is offline   Reply With Quote
Old 10-25-2006, 07:41 PM   #2 (permalink)
battlecat714's Avatar
Date registered: Sep 2005
Vehicle: 1994 040 E500
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
you can take a good look at it by just tugging at the trunk cover on the right side, if you haven't already.
battlecat714 is offline   Reply With Quote
gas smell, no signs of gas leak buckwyatt R/C107 SL/SLC Class 1 05-27-2006 07:53 PM
300CE Trunk Spoiler? hornbrod W124 E,CE,D,TD Class 9 02-10-2006 12:29 PM
89' 300CE with 100K LEAK!! tongzilla W124 E,CE,D,TD Class 2 11-07-2005 01:35 PM
Trunk Leak!!!??? Benzonline W126 S,SE,SEC,SEL,SD,SDL Class 5 11-25-2004 07:46 AM
Trunk leak Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 6 03-10-2002 08:04 PM
