Old 10-24-2006, 07:13 AM   #1 (permalink)
janos_z's Avatar
Vehicle: 1989 560 SEL, 1994 E320 wagon, 2007 C230
Fog light replacement
A friend asked me to help change the fog lights on a 1993 400E. I couldn't figure out how to remove the bulb cover, and the manual wasn't helpful. Does anyone have instructions or a diagram?
Janos
Current:
-1989 560SEL
Past:
-2007 C230
-1994 E320 wagon
-1993 400E
janos_z is offline   Reply With Quote
Old 10-24-2006, 05:10 PM   #2 (permalink)
Date registered: Mar 2006
Vehicle: 94 E420
Open Hood and detach Tubing from Air Box
Remove Plastic Air Scoops from rear of Headlamp Unit
Remove Rear Cover from Headlamp Unit (secures with two metal clips).
Using Flashlight Identify location of Foglamp Bulb, it is secured with a metal clip.
Push the two arms of the clip together and pull away from the fixture. This will allow you to then remove the bulb.
Its dark, and its cold. But I'd be more than happy to take a photo in the morning to explain the process.
Eliot is offline   Reply With Quote
Old 10-24-2006, 08:59 PM   #3 (permalink)
janos_z's Avatar
thanks -- that would be great. i got as far as removing the plastic air scoops, but couldn't locate the metal clips.
i've changed the headlights before, and those were much easier to figure out...
Old 10-25-2006, 07:51 AM   #4 (permalink)
Vehicle: 94 E420
Back in a minute
One
Two
Three
Four
Five
The white woven cable is the plug to the fog lamp bulb (H3). It will probably be quite yellow at this point.
Old 10-25-2006, 01:51 PM   #5 (permalink)
janos_z's Avatar
Eliot, thanks so much for those pictures -- but, unfortunately, you have a '94 and the car I'm trying to work on is a '93. They have different headlight assemblies, so the back of the lights on my friend's 400E isn't like the ones you've posted above...
Is there anyone out there with a first-gen w124 who can help out???
Old 10-25-2006, 07:32 PM   #6 (permalink)
battlecat714's Avatar
Date registered: Sep 2005
Vehicle: 1994 040 E500
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
doesn't the fog light have it's own separate cover?
battlecat714 is offline   Reply With Quote
Old 10-25-2006, 08:53 PM   #7 (permalink)
janos_z's Avatar
from the back, there is no cover. once i remove the plastic air scoops, the back of the headlight assembly is exposed. for the main headlight, it's a simple plastic clip -- you press the sides of the clip together, and the bulb socket slides out; then you just remove the old bulb, pop in the new one, clip everything back into place, and you're done.
but for the foglight, there's no corresponding plastic clip -- it's a different fastener, and i've tried pulling it, pushing it, whatever, and it didn't budge. i wish i had pictures, but the car isn't mine so i can't just run downstairs with my camera...
this should definitely be a DIY thing; i'm surprised the manual doesn't really cover it...
Old 10-25-2006, 09:15 PM   #8 (permalink)
oohhhh 400e...my bad.
Fog light replacement janos_z W124 E,CE,D,TD Class 0 10-22-2006 10:05 PM
Replacement Fog light! Easty R171 SLK Class 1 02-27-2006 10:47 AM
SLK55 Fog Light Replacement shark22 R171 SLK Class 2 10-21-2005 02:22 PM
fog light replacement bailey R170 SLK Class 5 05-21-2005 01:17 PM
ML55 Fog Light Replacement vsNYC W163 M-Class 1 11-18-2004 03:04 PM
