» Site Navigation
» Other Sites
Old 10-18-2006, 10:33 AM   #1 (permalink)
Date registered: Mar 2006
Vehicle: 1991 Mercedes 300E
Send a message via MSN to pyro_la
rattle locating help needed
91 300E. when the car is in nuteral or park its fine only when the car is in drive or reverse(under load) there is a rattle. always there, but when i give it very little gas and bring the revs up ever so lightly the rattly stops. what could it be any ideas, and has anybody ever head or seen this before. its more annoying then anything, and i dont think is a perfomance or maintenence issue. im thinking like a loose something or other. any ideas?
pyro_la is offline   Reply With Quote
Old 10-18-2006, 12:46 PM   #2 (permalink)
Date registered: Oct 2006
Vehicle: 1998 E320
Sounds like the problem I just had fixed. Engine mounts and/or tranny mount. Most likely engine mounts. Do a search on the forums. Lots of posts regarding your issue.
Texas is offline   Reply With Quote
Old 10-19-2006, 08:34 AM   #3 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
It could also be your cat. converter. Mine had an odd "rattle" sound that would go away as soon as I gave the car any gas at all. In my case, it was the converter.
Good Luck,
Jayare
Jayare is online now   Reply With Quote
Old 10-19-2006, 08:42 AM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 1999 Euro C280 Sport
Maybe its not the cat. I had mine rattling fixed this morning. It turns out to be the bracket/buffer which hold the muffler together. Mine got to loose even if its fully tight. So i had to remove it. My muffler is still mounted using the rest of the brackets. I though also it could be the cat, but when the ASE Muffler tech look at it the bracket started to rattle. This bracket is not mounted to the car, it just hold the twin pipes in place with a bold in the middle.
Eddie
Curacao is offline   Reply With Quote
Old 10-23-2006, 07:05 PM   #5 (permalink)
Date registered: Jan 2003
Vehicle: 87 300TD, 68 250S
most definitely your driver's side engine mount. when there's load in reverse that's where the engine tilts to
Locry is offline   Reply With Quote
Old 10-23-2006, 10:07 PM   #6 (permalink)
nickCR's Avatar
Date registered: Jul 2005
Vehicle: 1996 MB C280
my muffler did this too however my problem was in the very back.
They normally are held on there with a rubber o-ring (a heavy duty one) but it wasn't doing the job. I had the guy just solder the pieces together so there was no more problem. Worked like a charm.
~ Nick
Costa Rica
1996 Mercedes Benz C280
1988 Mercedes Benz 300E (SOLD)
My site TicoVista for costa rica real estate and more.
nickCR is offline   Reply With Quote
Old 10-24-2006, 02:55 PM   #7 (permalink)
dahappybanana's Avatar
Vehicle: 1990 300E, 2002 ML500
Send a message via ICQ to dahappybanana Send a message via AIM to dahappybanana
Is it more of a rattle as in just a noise, or is it a shimi that shakes the car? If it is a shimi then I would put money on engine monuts.
dahappybanana is offline   Reply With Quote
Old 10-24-2006, 10:17 PM   #8 (permalink)
the car does run a little rough, you can feel it. also i donno if its the exhaust as i removed the resonator and installed new piping and aa new muffler, although it can still be the cat. but im leaning more towards the engine mounts as they have never been changed, it had 17k and it is running a little rough. what you think?
Old 10-25-2006, 07:47 AM   #9 (permalink)
gld
Date registered: Apr 2005
Vehicle: 1988 300CE
It could also be the steering damper, the shock absorber looking thing in front of the thermostat housing. With the engine running, press down on it with a screwdriver or stick to see if the rattle stops.
gld is offline   Reply With Quote
Old 10-25-2006, 01:44 PM   #10 (permalink)
Jayare's Avatar
The steering damper is located under the car and is not your rattle problem. What GLD is referring to is the belt tensioner shock absorber. It is located exactly where stated above. Only the very upper most part the shock is visible. Very possible that the bushing in the upper part has worn out. Happened to me.
Good luck,
Jayare
Help needed with locating part...desperate! IIGood W201 190E, D-Class 14 10-10-2006 02:36 PM
Need Help Locating a Wheel... bse500sel W126 S,SE,SEC,SEL,SD,SDL Class 3 06-27-2006 11:25 PM
Brake Rattle .... "Anti-Rattle Spring"? jek9372 W201 190E, D-Class 5 03-30-2006 01:26 PM
Help needed in locating fender mouldings for a 300 GD 1985 RANA G-Class 11 06-05-2005 02:58 AM
Need help locating a G overseas PHIL G-Class 8 11-16-2001 01:32 AM
