» Site Navigation
» Other Sites
Old 09-27-2006, 12:47 PM   #1 (permalink)
nickCR's Avatar
Date registered: Jul 2005
Vehicle: 1996 MB C280
DIY Door Cover Removal?
Anyone know where I can find a DIY door cover removal guide? I have something rattling around in my right side passenger door and I want to fix it right away.
~ Nick
Costa Rica
1996 Mercedes Benz C280
1988 Mercedes Benz 300E (SOLD)
My site TicoVista for costa rica real estate and more.
nickCR is offline   Reply With Quote
Old 09-27-2006, 04:57 PM   #2 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 02 Olds Aurora
Nick,
Go here - www.braingears.mb.com - Repair manual on-line. There, you will find the steps to remove the door panel. It isn't that big a deal at all. Should take you about 20 min. to remove.
Good Luck,
Jayare
Jayare is offline   Reply With Quote
Old 09-27-2006, 06:15 PM   #3 (permalink)
Date registered: Sep 2006
Vehicle: 1987 Mercedes 260E
Send a message via MSN to 87260E
Check the Address. It is incorrect.
87260E is offline   Reply With Quote
Old 09-27-2006, 06:52 PM   #4 (permalink)
Jayare's Avatar
Sorry for that. It is http//:mb.braingears.com
Jayare
Old 09-27-2006, 08:58 PM   #5 (permalink)
vili1982's Avatar
Date registered: Jan 2005
Vehicle: 95 E320 Coupe, Diesel Golf
Send a message via MSN to vili1982
I've been trying to remove mine for a while now it's just not working out, I guess I'm just affraid to pull and brake something.
In the world of roads, there are those who travel and those who own it. The choice is yours.
95 Coupe
vili1982 is offline   Reply With Quote
Old 09-27-2006, 09:04 PM   #6 (permalink)
vili1982's Avatar
Jayare
it's actually http://mb.braingears.com, and that online manual sucks and it's full of broken links.
Old 09-27-2006, 11:10 PM   #7 (permalink)
battlecat714's Avatar
Date registered: Sep 2005
Vehicle: 1994 040 E500
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
not all the time.
battlecat714 is offline   Reply With Quote
Old 09-28-2006, 04:35 AM   #8 (permalink)
joef's Avatar
Date registered: Jan 2004
Vehicle: 93 300CE Cabrio, 99 ML430, 94 E320
Hey Guys,
It's really no big deal to pull the door panels off.
Undo all of the screws that are visible on the back side of the door end.
Pop the door controls cover off and undo the philips screw that's holding them in.
Pop the small panel at the mirror location
Undo the 10mm bolt that hold the handle. And if memory serves me correctly that should be it.
Last but no least pull the door panel back and up simultainiously.
It's a little un-nerving at first. But I've pull mine off quite a few time's when working on the stereo.
When you're putting it back just make sure you have all the tabs sliding into sleeves before you push it back into place.
Vili, I'll help you out when we work on you stereo.
Joe
joef is offline   Reply With Quote
Old 09-28-2006, 06:05 AM   #9 (permalink)
vili1982's Avatar
Joe, check your email.
Old 09-28-2006, 08:40 AM   #10 (permalink)
desperadoresearch's Avatar
Date registered: Aug 2006
Vehicle: 92 300E, 91 300E
Okay, I popped mine off last night in the dark in about 20 minutes. Passenger side rear in a 300 E.
Remove the door lock button or whatever you call it.
The key is lifting the panel up, hard, don't worry nothing will break, it just feels that way in comparison to American cars.
The next key step once he panel is up far enough to see behind, notice the screws that hold the wood trim on. Mine were 7mm. Undo them all and take the wood trim piece off. Now the handle and window switch will have more freedom.
I now used a paint scraper to gently push the handle and switch out of the panel.
When handle cover and switch are out, you will see the 10mm bolt that holds the handle and pretty much the panel to the body. remove it.
Now it will just fall off the vehicle.
Good luck.
Joe
desperadoresearch is offline   Reply With Quote
Driver's window motor removal. Any DIY help. rcs hawaii R129 SL Class 1 08-12-2006 09:03 PM
Looking for DIY about changing the timing cover gasket wylliera W124 E,CE,D,TD Class 3 08-08-2006 02:19 PM
DIY - Tail light (Sedan) Removal BF_JC230 W203 C-Class 0 04-06-2006 05:43 PM
Does anyone have a DIY for removing the bumper cover? trbo2nr W202 C-Class 1 02-25-2005 06:57 AM
Headlight removal,(bumper cover removal?) racingdave W203 C-Class 5 01-13-2005 10:05 AM
