» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 09-20-2006, 09:16 PM   #1 (permalink)
Date registered: Feb 2005
Vehicle: 1995 E320
Remove plastic body cladding E320
I need to respray the lower body cladding on my 1995 E320. It's probably easier to pop off the panels and spray them while they're off the car. Has anybody tried this? How easily do the panels pop off? Do you need to replace the pieces that hold them on? Any suggestions as to how to pop them off without damaging anything? Thanks.
Bob J is offline   Reply With Quote
Old 09-21-2006, 06:11 AM   #2 (permalink)
mbenzman's Avatar
Date registered: Oct 2003
Vehicle: 6.9. 300E ML55 500E S320 CLK55 Designo Cab
Yes, I have.
The door mouldings have screws at rear inside edges, , pop loose at bottom and slide forward or rearward at the top to disengage. the front fender cladding and the rear fender cladding have snps top and bottom. The rocker panels then can be removed by pulling the seal for the bottom edge of the door cladding and removing the screws there and underneath the car.
Rich
mbenzman is offline   Reply With Quote
Old 09-21-2006, 04:21 PM   #3 (permalink)
nickCR's Avatar
Date registered: Jul 2005
Vehicle: 1996 MB C280
The piece below those door panels are side skirts. Is it stock or did you buy them aftermarket?
Are the clips on the bottom of the door necessary? I bought these new sides from eBay and I will try installing them soon after they arrive. However I am a little concerned now that they will not work right without changing the doors. Maybe just installing clips there is easy enough.
~ Nick
Costa Rica
1996 Mercedes Benz C280
1988 Mercedes Benz 300E (SOLD)
My site TicoVista for costa rica real estate and more.
nickCR is offline   Reply With Quote
Old 09-21-2006, 05:27 PM   #4 (permalink)
janos_z's Avatar
Vehicle: 1989 560SEL, 1993 500E
that's a 500E, so the trim, especially around the fenders, will be a little different from a 300E or a 400E.
Janos
Current:
-1993 500E
-1989 560SEL
Past:
-2007 C230
-1994 E320 wagon
-1993 400E
janos_z is offline   Reply With Quote
Old 09-21-2006, 09:27 PM   #5 (permalink)
battlecat714's Avatar
Date registered: Sep 2005
Vehicle: 1994 W124.036
Send a message via AIM to battlecat714 Send a message via Yahoo to battlecat714
if you're bothered by the door panels sticking out or just seeing it loose, then they're necessary.
battlecat714 is online now   Reply With Quote
Old 09-21-2006, 09:47 PM   #6 (permalink)
mbenzman's Avatar
The piece below those door panels are side skirts. Is it stock or did you buy them aftermarket?.
Side Skirts are factory 500E parts and won't fit your 300E. Your sig. shows you have a 88 300E, Mercedes did not install cladding on the w124 until 1990, so your does not have any of these pieces.
If you like them flapping and possibly being ripped off in the wind then don't install the proper clips.
Old 09-22-2006, 01:27 AM   #7 (permalink)
nickCR's Avatar
Sorry didn't mean to jack the thread, just I bought the mouldings all around for my 88 and i'm going to simply have to find a way to secure them because that just not gonna fly (flapping around), the way I drive between the pot holes and quick breaking (at times) it is definitely required to have them secured..
Not a fan of the 90's cladding...remove it?? gerkebi W124 E,CE,D,TD Class 1 02-23-2006 07:42 PM
Paint Codes for plastic cladding Bob J W124 E,CE,D,TD Class 8 02-18-2006 05:36 AM
wax the body cladding? andrew_falky W126 S,SE,SEC,SEL,SD,SDL Class 2 07-12-2005 03:30 AM
Spray Paint for W126 body cladding alydon W126 S,SE,SEC,SEL,SD,SDL Class 2 07-10-2005 01:26 PM
How to remove lower body cladding? MS Fowler W126 S,SE,SEC,SEL,SD,SDL Class 1 10-04-2004 02:07 PM
