Old 09-15-2006, 09:55 PM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 89 300e
Rattling noise - Don't think it's engine mounts
Hey all, newbie here and have a question. My 300e makes a rattling noise that sounds like it's coming from towards the rear, and it only rattles when I'm coasting or braking. It does NOT rattle when I'm accelerating or idling. Any thoughts on what this could be? I've searched the forum, but all the "rattling" references don't seem to be the same problem as mine. Mine distinctly only happens when coasting or braking. Seems odd.
My friend thinks I need to replace the axle assembly, but just wanted to see if anyone else has experienced this before I fork out the cash to replace it. Thanks in advance.
-Brian
'89 300e
bvmags is offline   Reply With Quote
Old 09-17-2006, 12:55 PM   #2 (permalink)
Inline6's Avatar
Vehicle: '87 260E, '97 Nissan VQ Cefiro
Transmission support??
Inline6 is offline   Reply With Quote
Old 09-17-2006, 07:08 PM   #3 (permalink)
nickCR's Avatar
Date registered: Jul 2005
Vehicle: 1996 MB C280
I would suggest you check your transmission support however the spare tire and the jack if not fastened correctly will MAKE that rattling noise. I have the same problem but it's because of my sub-woofer box.
~ Nick
Costa Rica
1996 Mercedes Benz C280
1988 Mercedes Benz 300E (SOLD)
My site TicoVista for costa rica real estate and more.
nickCR is offline   Reply With Quote
Old 09-17-2006, 08:08 PM   #4 (permalink)
Vehicle: 89 300e
Thank you
Thanks for the responses. Is the transmission support the same as the transmission mount? (part no. 1242400618).
Thanks again
-Brian
Old 09-18-2006, 12:27 AM   #5 (permalink)
Date registered: Feb 2005
Vehicle: 1995 Mercedes-Benz E420 Special Edition
Send a message via AIM to chrisdpham Send a message via Yahoo to chrisdpham
Is your shifter loose?
If so - it could be your shifter bushings that went out and needs replacement.
Also check the rear end and see if your control arm is broken.
chrisdpham is offline   Reply With Quote
Old 09-28-2006, 09:22 PM   #6 (permalink)
Vehicle: 89 300e
Update...
Hey all, thanks for the ideas.
My mechanic friends has checked out the car, and I showed him all your replies and he's pretty sure it's not any of the suggestions you gave. BUT, he's still stumped.
Here's some more info:
We tried the axle route. We jacked the car up, took off the tire and axle, started the car up, stepped on the gas, and no more rattle! Naturally, we thought it was the axle. So we proceeded to replace it. Once we put the new (used) axle and tire back on, back came the rattle.
Again, it's only when I let up on the gas. If I'm coasting = rattle. If I step on the brake = rattle. If I step on the brake AND give it a little gas at the same time = NO rattle.
We took off the heat shield and we really couldn't pinpoint exactly where the noise is coming from. The differential is running oil through it, so we pretty much discounted that as the problem (should we have?).
Any other thoughts? I think I'm just going to have to pony up at the dealer for a diagnosis.
Old 09-29-2006, 08:35 AM   #7 (permalink)
GHM
GHM's Avatar
Vehicle: 1986 300E 3.0
Just a shot in the dark, could be the catalytic converter, when they start to go out they sometimes rattle. Just a thought.
GHM is offline   Reply With Quote
Old 11-20-2006, 09:47 AM   #8 (permalink)
Vehicle: 89 300e
Hey all,
Just an update, in case anyone is interested. The noise turned out to be the differential. My mechanic thinks that before the car was sold to me, the seller dumped a bunch of oil into the differential making it seem okay. It turns out that the gears in the differential were severely cracked...actually broken! New differential = problem solved! No more rattling!
Old 12-12-2006, 05:32 AM   #9 (permalink)
Date registered: Jul 2006
have the same problem with my car.
what is the part number for the differential ?? is there only 1 part ??
how much did u pay for the part ??
thx
drag1 is offline   Reply With Quote
Rattling noise under car - cats replaced - check engine light Godiva W210 E-Class 5 12-20-2006 05:45 PM
Engine Rattling Noise frost_dxb W203 C-Class 0 09-19-2005 11:15 PM
rattling noise Tatnhu W163 M-Class 0 05-03-2005 08:13 AM
Rattling Noise Storm. W210 E-Class 1 08-10-2004 01:40 PM
rattling noise... daniz88 W201 190E, D-Class 1 03-27-2003 11:51 AM
