Old 09-15-2006, 01:44 AM   #1 (permalink)
92 400E Power steering pump and water pump, need advice
Hello, I am a new owner of a 92 400E with 170K. First time Mercedes owner. With its age, it will need a lot of maintenance to bring it up in good health. Currently, there is a big power steering leak and I suspect it is the hose between the reservoir and the pump. Because the pump has been run without fluid few times, I bought a rebuilt pump from autohaus to replace the leaking one. I removed the 2 bolts that hold the steering pump bracket ( one under the reservoir and the other one behine the bracket on the driver side), but the bracket don't want to come off. Am I missing a bolt somewhere?
Also, as part of the maintence, i like to replace the water pump. However, I see that one of the mounting bolts is behind the big harmonic balancer. I don't see a way to loosen that bolts without taking out the cooling fan bracket (that will make me to take out the alternator) and the harmonic balancer. If I am right, is it worth it to do? Or should I wait until the water pump fail?
Beside that, here is my maintence list to bring the 400E back to life:
change out tranny fluid filter, tranny fluid, oil change, caps, rotors, wires, plugs, new power steering pump, filter, differential oil, drive belt change, new fan clutch, coolant change, thermostat change, and drive belt tensioner change.
Am i missing anything?
kanio is offline   Reply With Quote
Old 10-01-2006, 04:51 PM   #2 (permalink)
Date registered: Dec 2004
Hook-up with Alldatadiy....to replace the PS pump you pretty much need to remove alot of the stuff on the front of the engine, don't cut corners, remove the rad first. Lotta work. While you're there, do the water pump!!. It is a BIG job to do the PS pump but it needs doing on the M119...they all leak......and it will leak again..
Brian McL is offline   Reply With Quote
Old 10-02-2006, 06:00 AM   #3 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
Why are you replacing parts that may not need replacement yet? Is the water pump leaking?
Sergio
'95 E320 177K miles
Sergio is offline   Reply With Quote
Old 03-19-2007, 02:40 PM   #4 (permalink)
Date registered: Feb 2007
Vehicle: 500E
Sergio
'95 E320 177K miles
Fuel filter and pvc valve (if you have one.)
Jack Ilves is offline   Reply With Quote
Old 03-19-2007, 05:51 PM   #5 (permalink)
Date registered: Apr 2006
Vehicle: 1994 E420
PS Pump
My E420 has 220 000 miles, just replaced the PS pump and water pump at same time. Big job, yes had to remove rad. Got a PS pump rebuilt from autohaus and an aftermarket water Pump.
1994 E420
1990 300D 2.5 White
1990 300D 2.5 Beige
1981 300SD
timt is offline   Reply With Quote
Old 03-19-2007, 05:58 PM   #6 (permalink)
Vehicle: Benz 260E and others
Check this out.
That could probably help
Scrool down to the last page;
JackD
1989 260E
2006 Mazda 5
1978 Corvette
1974 MGB
1998 Southwind Motorhome
1996 John Deer lawn mower tractor.
Jackd is offline   Reply With Quote
463 G300 Replace Water Pump - advice JK G-Class 0 07-23-2006 02:54 PM
Power Steering Pump bwaymire W124 E,CE,D,TD Class 0 11-30-2005 07:50 AM
Water pump leaking steering pump loud abentley79 W124 E,CE,D,TD Class 3 08-31-2005 04:50 AM
Rattling sound near water /power steering pump..S320 (1995) azr67 W140 S-Class 2 02-01-2004 11:57 AM
Power steering pump (???) Guest (MBNZ) W201 190E, D-Class 11 02-09-2002 09:06 AM
