» Site Navigation
» Other Sites
Old 09-08-2006, 09:21 AM   #1 (permalink)
Date registered: Aug 2006
Vehicle: 1990 Mercedes 300CE, Black/Black - H&R, Bilstein, etc.
Will the "Plumbing Valve" work with a 300CE (24v engine)?
I turned down the fuel mixture screw last night (car was way rich) and now my car will not idle when cold, and idles very low/rough when warm.... As I posted before, the PO probably used the mixture screw to compensate for a bad ICV... Will the "plumbing" valve work with the 24v engine (M104)? Also, any other suggestions as to why the car might be idling so low? I put a new air cleaner in, new plugs, replaced the torn rubber breather hose, etc.... TIA!
Erwin8r is offline   Reply With Quote
"Yakuza" Sato's AMG Mercedes from "Black Rain" (starring Michael Douglas&Andy Garcia) JJB236 W124 E,CE,D,TD Class 20 08-06-2007 08:12 AM
500 SEC "brake bushings" & "castor supports" Graham W126 S,SE,SEC,SEL,SD,SDL Class 5 08-26-2003 12:14 PM
TIRES WANTED!! 265/30/19 "rear" 235/35/19 "front" bigjx76 W203 C-Class 0 08-05-2003 05:14 PM
300CE Going from 15" to 16" what are benefits/tradeoffs? Don 300CE W124 E,CE,D,TD Class 8 11-07-2002 06:44 PM
DREW - - On some posts your system puts a " " (space) in Message to kill the "NT" Jüri. W163 M-Class 3 08-07-2002 05:28 AM
