» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 07-25-2006, 11:08 AM   #11 (permalink)
You are right it is a M103. My mistake, Well the codes are probably different , well i know one is as the code list i have dosent have a code 13 ? Has anyone out there got a code list for the 103 Engine. I have codes 11-13-16 Flashing on the LED
Thanks
Lee
leetyler is offline   Reply With Quote
Old 07-25-2006, 12:39 PM   #12 (permalink)
Yal
Date registered: Sep 2004
1 No fault found
2 Throttle position switch - wide open throttle (WOT), signal faulty
3 Engine coolant temperature signal read by CFI control module
4 Potentiometer voltage illogical
5 Oxygen sensor signal illogical
6 Not used
7 TNA signal(rpm) read by CFI control module
8 Altitude pressure signal from ignition control module illogical
9 Current to EHA is illogical
10 Throttle position switch - closed throttle position fault (idle)
11 Air injection system, open or short circuit
12 Absolute pressure values from EZL ignition control module are illogical
13 Intake air temperature reading is illogical
14 Vehicle speed signal read by CFI control module is illogical
15 Not used
16 Exhaust gas recirculation switchover valve, open or short circuit
17 Oxygen sensor is shorted to positive or ground
18 Current to idle control valve is illogical
19 Not used
Yal is offline   Reply With Quote
Old 07-25-2006, 12:46 PM   #13 (permalink)
Jayare's Avatar
Date registered: Jun 2005
Vehicle: 86 190E 2.3 16V, 90 300CE, 93 400E, 98 S500
Yal,
Would these fault readings be the same for the M104 engine?
Thanks,
Jayare
Jayare is offline   Reply With Quote
Old 07-25-2006, 12:52 PM   #14 (permalink)
Val Thanks Man.
Well looks like iv got the following fault codes
11. Air injection system, open or short circuit
13. Intake air temperature reading is illogical
16. Exhaust gas recirculation switchover valve, open or short circuit
I'm not to up on these explanations. I'm a beginer to this DIY stuff but learning qiuckly, Could somone help me out with these readings and advise solutions?
Thanks
Lee
Old 07-25-2006, 02:41 PM   #15 (permalink)
Yal
Originally Posted by Jayare
Yal,
Thanks,
Jayare
Its for 124.026, 124.030, 124.090, 124.230, 124.290, from 1990-93
and 124.051, 129.061, from 1990-93 too.
Old 07-25-2006, 02:47 PM   #16 (permalink)
Yal
Originally Posted by leetyler
Val Thanks Man.
Thanks
Lee
I'm going to say that 13 is the air intake sensor on the air filter box.
Old 07-25-2006, 04:06 PM   #17 (permalink)
Jayare's Avatar
Yal, thanks for the code info.
Lee, What are you using to read these codes?
Jayare
Old 07-25-2006, 04:28 PM   #18 (permalink)
Jayare,
Not to sure what it's called but on the right hand side of the battery is a small black box, inside is a 16 pin number sequence and a small black button at the top, press and hold for three secounds and a small red LED flashes. this is what gave me the 3 error codes. It flashes until it gives you the fault, the repress for another 3 secounds if you have any more faults, i got 11.13.16 flashes then it riverted back to 11
Old 07-25-2006, 04:36 PM   #19 (permalink)
Jayare's Avatar
Thanks Lee,
Jayare
Old 08-09-2006, 10:27 AM   #20 (permalink)
Ok Guys,
I'm bringing this post back to life as i have been testing certain things with no success.
I tried removing the O2 sensor and intialy fault that the slow pull away problem was resolved. I was wrong as it came back as soon as the engine warms up.
I managed to fixed the fault 16 code issue with a new cold air intake as the old one has a big hole in the bottom, still have codes 11 and 16 showing on the internal Code reader.
Also replaced thermostat as i fault this might be the issue with the over heating problem but the old one was fine, changed it anyway. There seems to be no presure between the rad hoses and the water pump, with the engine running but not at high temp you can squezze these pipes " hoses" and there dose not seem to be any pressue in them. Have a feeling this may be a bad rad issue but im not sure. These are tje largest hoses in the engine bay.
This slow pulling away problem is really getting to me though. It's sitting at a light and when green comes along i can't even move the car. takes 20-30 seconds to reach 40 MPH. Absolutely drinking gas also getting less MPG than a V8 Tahoe !
The car feels very weak. Any advice or recomendations is appriciated.
Loss of Power............... PeteK W210 E-Class 10 11-25-2008 11:02 PM
HELP!!!!---loss of power yourfuture W208 CLK Class 4 03-08-2007 10:06 AM
Loss of power VCR G-Class 2 05-16-2006 04:10 AM
Can exaust leak (loss of compression) slow down car? skipinschool W210 E-Class 3 01-27-2006 08:54 AM
Power loss? Samir W208 CLK Class 1 05-01-2001 10:41 AM
