low beam not working...but high beams are?? - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-29-2006, 09:26 PM Thread Starter
my260e's Avatar
Date registered: Jan 2006
Vehicle: 1987 260E, 2000 C230, 2001 S500
Send a message via AIM to my260e
Hello, so my right low beam isn't turning on and i checked the fuses and the connections...everything is okay, so i thought i needed a new bulb, but when i checked the high beams it works fine. So correct me if i am wrong but since it is the same bulb, doesn't that mean there is a connection that isn't going through or what?? im confused and now i can't drive at night unless i flash people...so any thoughts?
thanks
-Nathan
my260e is offline
post #2 of 14 (permalink) Old 06-29-2006, 10:15 PM
Mouramen's Avatar
Date registered: Jul 2005
Vehicle: 1985 200D (w124) and Totaled 190D 2.0
it's the bulb, the same bulb has the low and high beam but in diferent contacts, it's very commom to only burn "half" bulb, swap the right with the left bulb and you will see the problem swaping sides too!
Mouramen is offline
post #3 of 14 (permalink) Old 06-30-2006, 10:57 AM Thread Starter
my260e's Avatar
my260e is offline
post #4 of 14 (permalink) Old 06-30-2006, 11:10 AM Thread Starter
my260e's Avatar
hrm..i forgot to ask, how do i change the bulb, the shop did it for me last time, i know i have to remove the panel by lifting it straight up and there is a couple of wires and a connector, do i just pull that thing out or am i supposed to unscrew it out? thanks
-Nathan
my260e is offline
post #5 of 14 (permalink) Old 06-30-2006, 02:13 PM
Mouramen's Avatar
Wink
See if this helps:
Mouramen is offline
post #6 of 14 (permalink) Old 06-04-2007, 03:06 PM
Date registered: Feb 2006
Vehicle: 1994 E320
Car: 1994 E320, 180k miles
I am having a very similar problem with both of my low beams. My fog lights work as do my high-beams. I do not believe it is the bulb, as both went out at the exact same time. I have replaced the fuses, and the light switch in the dash. I think that it is the high-beam lever on the steering column, but I am hesitant to pull it apart as of yet. I have access to a parts car (my best friend totaled his '94 E320 last week), so I have the part if that is the problem. I have looked at the wiring diagram and I can't think of any other place where the problem could exist.
Leonidas is offline
post #7 of 14 (permalink) Old 06-04-2007, 07:02 PM Thread Starter
my260e's Avatar
what I ended up doing was taking it down to the MBZ dealer and they sold me two replacement bulb harness's. Switched them out myself and viola!
my260e is offline
post #8 of 14 (permalink) Old 06-04-2007, 09:46 PM
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 23100 miles "Gunter", 1999 ML320 200000 miles "Fizgig"
headlight relay
Also under the plastic cover behind the fuses is the headlight relay. When it burns out it will stop suppling power to whatever lights it wants to. Multimeter the socket, no power replace the relay/check fuses of course. Suggest junk yard new they are about 200.
macdrone is offline
post #9 of 14 (permalink) Old 06-04-2007, 11:44 PM
augapfel's Avatar
Vehicle: About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, and 4Matics; drivers, projects, and parts
Quoted: 20 Post(s)
The headlights on my 88 260E would turn OFF when I switched from high beams to low beams. Very unsettling the first time it happened. If I fiddled with the beam change lever the lows would come on so I knew the problem was the steering column switch. I bought a new one and all ws well again. Not terribly easy to change that switch though. For one thing the big allen head screw holding the steering wheel on was VERY tight.
My260e, what harnesses did the dealer sell you? I know that the little harnesses that run from the headlamp bulb to the front lamp assembly connector on my car are shot. It seems that the terminals to the headlamp bulb oxidize, overheat, and then make poor contact. I've had to pop the hood and fiddle with the headlamp connector at times.
augapfel is offline
post #10 of 14 (permalink) Old 06-05-2007, 07:32 PM Thread Starter
my260e's Avatar
They sold me the harness from the headlamp bulb which I just cut off the old ones and soldered the new ones in. Just like yours, the plastic was melted and contact was terrible.
my260e is offline
