Old 05-20-2006, 10:51 AM   #1 (permalink)
Date registered: May 2005
Vehicle: 1993 300E 2.8, 1988 300CE, 2001 e320 4Matic,
intermittant abs light and no cruise control
I have a beautiful 1993 300e 2.8 with 57K origional. The abs light comes on and off with no specific pattern. Sometimes it comes on when I start and stays on for 1/2 minute and sometimes it stays on for an hour. Then other days it does not come on at all. The funny thing is the cruise control doesn't work whenever the light is on. Then when it goes off the cruise works again. Now yesterday the "brake pads worn" light began to flicker a little but never stayed on. I just had the car serviced and told my mechanic of this issue and he checked the brakes and said they are fine. Of course I couldn't get the lights to come on while the car was there. He said it has gremlins. Any help would be greatly appreciated.
allwheeldrive777 is offline   Reply With Quote
Old 05-20-2006, 06:15 PM   #2 (permalink)
Date registered: Apr 2005
I think the cruise control amp also has some abs functions. Located under the steering wheel and looks like ebay item 8057340975 ; I'm not afiliated with the seller, just providing you a look at another one similar. These are specific per engine I think.
85 2.2 190d soon 2b 4 sale
91 2.5 300d my driver
98 E300TD wife's
04 Silverado 2500HD Duramax
all white
2.2greaser2b is offline   Reply With Quote
Old 05-20-2006, 07:19 PM   #3 (permalink)
Does my problem sound like something the amp would cause intermittantly or does it go out completely? Thanks
Old 05-21-2006, 06:22 AM   #4 (permalink)
Yal
Date registered: Sep 2004
This is a classic OVP relay problem. Check that first.
Yal is offline   Reply With Quote
Old 05-21-2006, 09:07 AM   #5 (permalink)
Do you just replace it? or can you test it? Thanks
Old 05-21-2006, 06:31 PM   #6 (permalink)
Yal
Your best bet is to check the fuse(s) on top of the OVP. The circuits inside the OVP are fragile and they tend to corrode, if that is the case your best bet is to get a new one. But check the fuse(s) first.
Old 05-21-2006, 08:51 PM   #7 (permalink)
The fuse is okay but the relay was not fastened down. Someone left the screw out and it was hanging. Does it need to be grounded?
Old 05-22-2006, 06:22 AM   #8 (permalink)
Yal
Maybe yours was loose. Make sure its seated properly. Screw it dow if you can. You may have to disconnect the battery to reset the system.
Old 05-22-2006, 08:41 AM   #9 (permalink)
The_Cap'n's Avatar
Vehicle: E320 Coupe
Given the varied symptoms my money's on your engine wiring harness.
I'd check this before doing anything else.
The_Cap'n is offline   Reply With Quote
Old 05-22-2006, 08:56 AM   #10 (permalink)
The wiring harness had already been replaced. Any other sugestions?This morning the abs light came on for 1 min then went off and then the cruise didn't work. The light stayed off and then the cruise worked. Also sometimes when I press the brake the check brakes light comes on. When I take my foot off the pedal it goes off. Thanks Cap'n
