» Site Navigation
» Other Sites
Old 04-29-2006, 07:29 AM   #1 (permalink)
DnBtekhnic's Avatar
Date registered: Apr 2006
Vehicle: 2003 Mercedes C-230 SS Kompressor -- Brilliant Silver
Send a message via AIM to DnBtekhnic
need control arm and knuckle replaced...
i mentioned before that i had camber in the right front tire...i replaced the knuckle, i think it might be called a spindle with a used one and it turned out shitty...anyways, when looking up these parts online what would the knuckle part be under, i want to order the two myself and just pay labor and my friends shop. thanks. i want all new parts too.
DnBtekhnic is offline   Reply With Quote
Old 04-30-2006, 06:03 AM   #2 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
I think ,there is a cut off in the " 93 -94 models ? , you can get the ball joint separately on the older before 93 $40 . Newer than 93 you had to buy the A-arm complete assembly $170 -420 . Look under suspension - A-arm .
One Arizona supplier had them the cheapest.
Uboater is offline   Reply With Quote
Old 05-28-2006, 10:27 AM   #3 (permalink)
HI,
I JUST REPLACED BOTH LOWER ARMS (FRONT) COMPLETE AND THE SPRINGS TOO
CONTROL ARM ($CN)230 EACH. (93 wagon)
parts.autopartsonlinecanada.com
AQORPIONS is offline   Reply With Quote
