Need help with W124 Windscreen Heater De-froster Controls not opening top air vents
Hello,
I have a problem with my W124 E200 non air conditioned heater. The heating works fine from the face and floor level vents but when I switch the heater controls to windscreen I am not getting any air, either hot or cold, from the windscreen vents on the top of the dash.
I'd be really gratefull of anyone's advice or experience of this problem.
Thanks,
Graham
I have the same problem. Get air coming out of all ducts except the ones for the front windscreen.
I have been told it is a dashboard removal job to fix costing at least 10 hours of labour!!
I am now looking for a dashboard mounted electric heater to clear the mist!
W124 E320 Coupe 1994 (235 x 45 x 17)
The pod on the heater box may be bad, that is alot of labor. what is worse is there are 3 under there so if one needs replaced you better do the other two.
