» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Old 10-18-2006, 09:09 PM   #41 (permalink)
stummala's Avatar
Date registered: Dec 2003
Vehicle: 560SEC V12, 560SEC V8, E320 Wagon, 500E, ML55 AMG, ML320, 500CE V8, S500 4Matic Sport
Probably get a Sportline suspension....I haven't decided about the rear end ratio yet.
Satish
Satish Tummala
Motorwerks Group
http://www.motorwerksgroup.com
stummala is offline   Reply With Quote
Old 10-19-2006, 08:11 AM   #42 (permalink)
Vehicle: 9191 Mercedes 300ce
is there any difference with a 500e rear and the 300ce rear.Is the 500e unit stronger?
denorea is offline   Reply With Quote
Old 10-19-2006, 04:24 PM   #43 (permalink)
S.M. Autoworks's Avatar
Vehicle: '92 400CE, '83 500SEC, '98 S320
Don't need to be shown 'the way to do it'. Already doing it.... almost done actually. CIS-E to EFI... no prob. Droppin' the engine in early next week.
S.M. Autoworks is offline   Reply With Quote
Old 10-19-2006, 07:10 PM   #44 (permalink)
Bigpete123's Avatar
Date registered: Apr 2004
I hope you take pictures!
Bigpete123 is offline   Reply With Quote
Old 10-19-2006, 08:31 PM   #45 (permalink)
stummala's Avatar
Ok. But I'll show you how to add a 3.07 LSD diff with ASR (and ASR defeat), and a 722.370 transmission modified to selectively start in first gear and a tuned valve body with higher shift pressures to boot (like my V12 SEC conversion) and flared front and rear fenders.
Also, the vehicle (engine bay and all) are painted 197C Obsidian Black Metallic in our very own body shop's Devilbiss Concept Cure II full downdraft paintbooth....not in the parking lot...
And why a 400CE? If one's going through all the effort for 50hp? A 5.0L engine is just as easy to find, same amount of work. Hmmm....
For 275hp, a C36 motor is a bolt-in swap. A 4.2L V8 makes 268hp and weighs more. Now 322hp is a full 100hp more than stock plus 354 ft/lbs of torque (yes, 1992 LH OBD-1 motor and electronics). Some logic and reasoning should go into swaps too.
Old 10-19-2006, 09:09 PM   #46 (permalink)
stummala's Avatar
http://www.mbcoupes.com/500CE/500CE15.jpg
http://www.mbcoupes.com/500CE/500CE16.jpg
http://www.mbcoupes.com/500CE/500CE17.jpg
http://www.mbcoupes.com/500CE/500CE18.jpg
Some more....
Old 10-20-2006, 11:16 AM   #47 (permalink)
So I wish people would think before they speak.... To imply that no logic or reasoning went into this project is obsurd. The beauty of building a custom car is that you get to build it YOURSELVES. No one came over to your site and started nitpicking your build. The fact of the matter is, we are capable of building awesome cars. Maybe my budget didn't match up to yours, but I know this car will. BRIAN @ SMAW
Old 10-20-2006, 11:37 AM   #48 (permalink)
More Pics...
Here you go
Old 10-20-2006, 12:08 PM   #49 (permalink)
joef's Avatar
Date registered: Jan 2004
Vehicle: 93 300CE Cabrio TT, 99 ML430
Brian, you should be applauded for you efforts. Many of us can only dream of tackling such a project. If I myself had the know-how I'd be doing a similar type of conversion.
The 4.2/4.3 L V8 was something I had comtemplated getting done since there would be less efforts involved in installing it vs the 5L. (no transmission tunnel widening). Beside I'm sure with a chip and intake, 300hp isn't far off.
Keep the pictures coming.
Joe
joef is offline   Reply With Quote
Old 10-20-2006, 02:18 PM   #50 (permalink)
thanks Joe. will do
