Rough Idle and engine hesitation/misfiring at high rpm - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-15-2005, 08:31 AM Thread Starter
Date registered: Jul 2005
Vehicle: 1995 E320 Wagon
Fantastic forum here, I have learned alot over the years. Early this summer I purchased a nice 1995 E320 Wagon, and have been quite happy with it after performing some maintainance. It has been running very nice all summer until just recently. The car sat for 9 days then about 2 weeks ago, I went to drive it, and noticed it had a very rough idle, especially noticable when sitting at a light in drive. Doesnt matter if the car is cold or warm, still misfires. I also notice that under acceleration, it is sluggish and seems to misfire. In the past, a new set of wires, plugs and rotor (older W124) did the trick. Well I spent the $105.00 and replaced the wires and figured it would cure the issue. Unfortunately the same symptoms are still happening. I pulled each plug, and they look just fine, and were new only a few thousand miles ago. I checked to make sure I was getting a spark at each cyl using an inline spark indicator tool, and every one is indicating fine spark. Any ideas out there? I am planning on making a home brew diagnostic tool to see about what codes will come up. Where can I find the code lists and the "how to use" the led tool? Any and all help is much appreciated!
1962 Studebaker Hawk GT
1986 300SDL
1991 300TE
1967 Olds Delta 88 Conv.
1979 Porsche 930 (911 Turbo)
1986.5 Porsche 928S
2001 Kawasaki ZRX 1200R
2003 F250 TurboDiesel
1985 300SD (sold)
1984 300SD (running parts car)
slingerone2002 is offline
post #2 of 6 (permalink) Old 11-16-2005, 05:23 AM
Date registered: May 2003
Vehicle: E320 wagon
RE: Rough Idle and engine hesitation/misfiring at high rpm
Give it a test for bad injector O-rings. Get access to the base of each injector and give it a spray /puff of carburetor cleaner at the base of each one with the engine at the lowest idle after warming up . You will get an increase of RPM at the bad Seal / O-ring .They are .88 cents a piece about 2 hours to change ,if you have metric Allen tipped sockets - in 1/4 and 3/8 drive
Normally the car will run great 1500 - 4500 RPM even with bad O-rings ,as the vacuum is greatest at low idle. I changed mine last year.
Uboater is offline
post #3 of 6 (permalink) Old 11-16-2005, 11:49 AM Thread Starter
Thank you for the suggestion, I will give that a shot and let you know what I come up with. I did build one of those homemade diagnostic tools, and got a few codes off it, but am not sure what they mean, maybe you or someone else could help shed some light on it, definitely would be appreciated:
When I tested Socket #14 - I got code 9 and 11
Socket# 6 - I got code 3, 4 and 8
Socket # 8 - I got code 3
Any thoughts?
1986 300SDL
1991 300TE
1986.5 Porsche 928S
1985 300SD (sold)
post #4 of 6 (permalink) Old 11-16-2005, 11:51 AM Thread Starter
I should also mention that at 4000 rpm, the engine just "cuts out" and will no go to any higher RPM, almost like there is a governor or something.
post #5 of 6 (permalink) Old 11-17-2005, 06:06 AM
Yal
Date registered: Sep 2004
Crank position sensor.
Yal is offline
post #6 of 6 (permalink) Old 11-18-2005, 07:32 AM Thread Starter
Thanks for the suggestion...is this difficult to change?
