Timing Mark for 300E 2.6 ? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-03-2005, 04:03 PM Thread Starter
kanoti's Avatar
Date registered: Dec 2002
Vehicle: mercedes 350sdl, 2005 ML350, 1991 300E 2.6 to 3.0, 1988 300E
I just finished replacing a rebuit head on my 300E 2.6, since the chain had broken, I have to reset the timing, I have the service manual but it has no reference to setting the timing or locations for the timing mark on the crankshaft or cyliner head, I searched the whole forum but no one seems to have a specific answer, if you have any diagrams please post.HELP
Thanks
1991 300E 2.6
1986 300E 3.0
1991 350 sdl with 3.0 liter turbo diesel
kanoti is offline
post #2 of 6 (permalink) Old 11-04-2005, 06:52 AM
Yal
Date registered: Sep 2004
RE: Timing Mark for 300E 2.6 ?
Timing is set electronically.
The only thing you need to worry about I believe is the distributer shaft being aligned correctly at top dead center for a baseline. There is no way to set the timing.
Yal is offline
post #3 of 6 (permalink) Old 11-05-2005, 08:15 AM Thread Starter
kanoti's Avatar
First you have to set up the chain correctly, I need to know where the mark on the timing gear should be in relation to the TDC.
Thanks
1991 300E 2.6
1986 300E 3.0
kanoti is offline
post #4 of 6 (permalink) Old 11-18-2005, 04:49 PM
ben merc's Avatar
Date registered: Oct 2005
Vehicle: 230E ,C180,300E
Unless you removed the distributor body it will still be aligned with the crankshaft I think. .If you have changed the chain then there is a mark on the camshaft that alignes with the face of the cylinder head, and the tdc on the crankshaft is more visible with the pulley removed.
ben merc is offline
post #5 of 6 (permalink) Old 11-18-2005, 08:15 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
See step 22 in
http://mb.braingears.com/124_DISC1/Program/Engine/103/01-4150.pdf
lkchris is offline
post #6 of 6 (permalink) Old 11-19-2005, 04:23 PM Thread Starter
kanoti's Avatar
Thanks a bunch, I couldn't find that info in the service manual
1991 300E 2.6
1986 300E 3.0
kanoti is offline
