» Site Navigation
» Other Sites
Old 04-25-2007, 11:04 AM   #21 (permalink)
Date registered: Feb 2007
Vehicle: '85 300D '89 260E '84 300D Z71, EZ-GO, M4 carbine, AK-47, mighty mite, exmark lazer Z.
aint that the truth....
mountainredneck is offline   Reply With Quote
Old 07-02-2007, 03:47 PM   #22 (permalink)
MiguelXJ's Avatar
Vehicle: '91 230CE; '93 220E Sportline
Hey,
I wanna try this on my 1991 230CE, but I have 2 questions:
- My X11 connector has less pins, if I recall correctly... 9 pins? Can I still use the #3 for this adjustment?
- The tower with the adjustment screw has a yellow cap on top... Is this removable? Or should I just press it in and turn?
Thanks
MR
1991 230CE
1993 220E Sportline
1989 200TD - sold
MiguelXJ is offline   Reply With Quote
Old 07-03-2007, 02:43 PM   #23 (permalink)
MiguelXJ's Avatar
Originally Posted by MiguelXJ
Hey,
Thanks
MR
anyone?
Old 07-04-2007, 07:43 AM   #24 (permalink)
MiguelXJ's Avatar
Well,
I found out that my 9 pin connector has the same function on pin #3... That's cool.
But I'm still puzzled about the yellow cap/protection on the top of the adjustment screw / tower...
Did anyone had to remove it?
Old 07-04-2007, 07:44 AM   #25 (permalink)
desperadoresearch's Avatar
Date registered: Aug 2006
Vehicle: 92 300E, 91 300E
I haven't seen a yellow rubber cap, but that would limit your ability to get an allen wrench down the tube to the adjustment screw. I'm fairly sure the cap should be removed and it is just there in place of the bearing that usually blocks access to this adjustment.
desperadoresearch is offline   Reply With Quote
Old 07-04-2007, 10:27 AM   #26 (permalink)
Date registered: Apr 2006
Vehicle: '92 200E M102
Yes, you have to remove that plastic yellow cap.
I have pierced it with a small screwdriver and then I have extracted it
Bombo101 is offline   Reply With Quote
Old 07-04-2007, 10:33 AM   #27 (permalink)
MiguelXJ's Avatar
Thank you, both.
I'm gonna get my multimeter and measure the average voltage on Pin #3 and I'll be right back
Old 07-04-2007, 01:02 PM   #28 (permalink)
MiguelXJ's Avatar
Well, by the readings I got, I'm at aprox. 37% duty cycle!
Gotta get that yellow cap outta there so I can tune it up to 45-50%
Thanks for all the help!
Old 07-04-2007, 01:43 PM   #29 (permalink)
MiguelXJ's Avatar
BTW,
Good link with lots of info about this subject:
BOSCH KE3-JETRONIC MIXTURE ADJUSTMENT
Old 07-10-2007, 03:12 PM   #30 (permalink)
MiguelXJ's Avatar
Update:
Did the FUEL mix adjustment, and now it purrs like a kitten!
I managed to get it up to a lil bit more than 50% (lean) and it sounds perfect.
Lets see if I notice smthg on the mileage!
Thanks for the help guys!
