Old 08-06-2005, 08:17 PM   #1 (permalink)
Date registered: Jun 2005
(O) lamp flashes while backing up
My car is a 88 300E.
I noticed that as of a few days ago, my 'brake pads wear' indicator lamp flashes intermittently while backing up. It really looks like an electrical/ground problem, since it's not a constant blinking but more of a loose cable kind of thing. The light goes off entirely while driving forward, and the brake pads look fine.
Anybody else had this problem, and can give me a clue where to look at?
Thanks.
ElNono is offline   Reply With Quote
Old 08-03-2007, 10:38 PM   #2 (permalink)
hispassion's Avatar
Date registered: Nov 2006
Vehicle: 1986 300E - (sold to step daughter); 1990 300E - 182,000 miles.
Send a message via AIM to hispassion Send a message via Yahoo to hispassion
Interesting. I've had the same problem. Will be looking in to it Saturday. If I find anything, I'll post back later.
I'm not who I think I am, and I'm not who you think I am, but I am who I think you think I am.
hispassion is offline   Reply With Quote
Old 08-08-2007, 07:47 AM   #3 (permalink)
hispassion's Avatar
Ok, found the problem. It was caused by a previous repair (that I didn't do). Seems someone replaced the front brake pads without sensors, but left the sensor wire just dangling there. This also explains why the (0) light came on in the car wash too. The wires were bare and freely conducting electrons. The pads are in good shape, but on my next order with Autohauz I'll get the correct pads and some new wires.
Old 08-08-2007, 09:01 AM   #4 (permalink)
Mouramen's Avatar
Date registered: Jul 2005
Vehicle: 1985 200D (w124) and Totaled 190D 2.0
Thanks.
take out the sensors and check if they are starting to wear out, when tey start to wear they will do that, first the light starts to blink, only after a while the light constantly lights when breaking!
Mouramen is offline   Reply With Quote
Old 08-08-2007, 10:15 AM   #5 (permalink)
Date registered: Jul 2007
Vehicle: 1992 300D 2.5 Turbo
The issue of the lights coming on when backing up is usually the result of the sensor tip getting bent, so it looks like it's in but the tip actually is bent aside and touching the rotor.
Romanow is offline   Reply With Quote
Old 08-14-2007, 09:39 AM   #6 (permalink)
mvmiller's Avatar
Date registered: Aug 2005
Vehicle: 2002 S500 W220;1986 190E W201; 1991 420SEL W126
Talking
You should ALWAYS replace the wear indicators (wires) every time you replace the brake pads. The last time I bought them (2 for each front wheel) I paid $1.95 each at the dealer!!
So for @ $8.00 it saves you alot of hassle... so the next time the light comes on you know it is your pads and not some half assed repair job gone haywire.
mvmiller is offline   Reply With Quote
