MY RUNNING LIGHT R/S REAR DOES NOT WORK. I HAVE CHANGED THE 10WATT BULB TO NO AVAIL. I KNOW THE BULB IS GOOD OF COURSE BECAUSE IT WORKS ON THE L/S. ANY SUGGESTIONS ON WHAT TO DO TO FIX. I HAVE ALSO CHECKED THE FUSE ALL GOOD. BRAKE LIGHTS WORK AS WELL AS TURN SIGNAL. I JUST CANNOT FIGURE THIS ONE OUT. THANK YOU
Did you just swap out the bulb? There might be a little corrosion in the socket that might have to be sanded out. That could be preventing the metal from making good contact.
1987 mercedes 300E
1989 engine(long story)
1995 e320 conversion(hated the 300e grill)
HID/Xenon (D2S)
Keyless Entry
Monochromatic Paint (Custom Blue)
Smoked Tails
Flat Badged (front)
Debadged (rear)
custom "carbon fiber" console
18 inch HP EVO rims
Sold! Now I drive a Monte Carlo SS
mission accomplished, found out that the contact was not being made. A little clean up and viola, but I think I need to replace the plastic panel due to some cracked pieces. Any ideas on where to find just the inside plastic that holds the bulbs?
