Old 07-25-2005, 11:10 AM   #1 (permalink)
ifrad's Avatar
Date registered: Jul 2005
Vehicle: 1993 300 E
Kick Down Button
What is a Kick Down Button where is it and what does it do?
1993 300E 2.8L
ifrad is offline   Reply With Quote
Old 07-25-2005, 01:03 PM   #2 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
RE: Kick Down Button
The kickdown button is situated behind the throttle pedal on the floor.
With the engine off, press the throttle all the way to the bottom and you will then feel the button click.
This is used when you need to get away quickly. If you hit the kickdown button from a standing, start, the car will start off in first gear instead of second like normal.
Whilst driving along the road, it will drop down to the lowest gear possible for that speed giving you a huge power boost.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
