Old 06-11-2005, 06:29 AM   #1 (permalink)
Date registered: Dec 2004
Vehicle: 94 E420
Trailer Hitch???
I have been thinking of adding a trailer hitch to my 94’ E420[:O]. It's primary function would be to mount a hitch-mounted bike rack. But, maybe I could tow a small utility trailer and keep the big junk that a homeowner always seems to have to drag around out of the back seat or the trunk[:D]
Any thoughts on light-duty towing with my car and/or trailer hitch fitment? Best place to buy a hitch?
Thanks,
Colorado
Colorado E420 is offline   Reply With Quote
Old 06-11-2005, 08:57 AM   #2 (permalink)
Date registered: May 2003
Vehicle: E320 wagon
RE: Trailer Hitch???
I found this on etrailer.comÂ*,
1994Â*Mercedes-BenzÂ*E420 Accessory Finder Change
Vehicles
Rear Mount Hitch Choose from the following selection of hitches that were custom designed to fit your vehicle.
If you have any questions you can contact our customer service department.
Searching Rear Mounted Trailer Hitches for:Â*1994Â*Mercedes-BenzÂ*E420
Â*
Class I Sport Frame Receiver Hitch Part Number: 24558
List: $273.53
Today: $146.42
Â* 1-1/4" Hitch Opening
Difficulty Level: 10 Â*
Â* Fits Mercedes-Benz E420 Sedans Only, Will Not Fit Wagons
2,000 Towing Detailed Info...Actual Photo Hardwire your vehicle. Â*
Â* Â* Use optional drawbarÂ*3593. Â*
Â* Trunk access required for hitch installation Â*Difficulty level is an indication of the installation time required.
All installations are bolt-on and require no welding. Some installations require drilling but most newer applications use existing holes in the vehicle frame.
Typical installation instructions are available on most items by following the Detailed Info... link above.
Beta Sort Feature
Vehicle StyleÂ*|Â* DifficultyÂ*|Â* PopularityÂ*|Â* Draw-Tite OnlyÂ*|Â* Hidden Hitch OnlyÂ*|Â* Reese OnlyÂ*|Â* No Sort
Uboater is offline   Reply With Quote
