» Site Navigation
» Other Sites
Old 05-31-2005, 09:36 PM   #1 (permalink)
drtung
Date registered: Aug 2003
Vehicle: E220 1994
Power antenna mast fixed
symptom: The first thickest section of the mast does not retract.
Remove mast - unbolt the top screw at the base of the mast. Switch on radio and quickly got to the back and pull the whole mast out.
Examine- any loss teeth on the nylon white strap. Spray lots of silicone into the mast. Hit the mast on the ground till the unretracted portion get into. repeat lunbrication and rotate the section till it gets smooth to retract.
Reinsert mast with teeth pointing bottom. Switch off radio and the gear with catch the nylon strap. Retraction complete and tighten the screw.
It should take less than 10mins. But the red straw on the silicone can sprayer dropped into motor "black hole" accidentally and I need to dissemble the whole thing. And found the gear/ motor inside was all filled with firts and soots. Clean it and re-lubricate that with grease. The motor now sounds complete silence.
drtung is offline   Reply With Quote
Old 06-01-2005, 08:28 AM   #2 (permalink)
1stW124
1stW124's Avatar
Date registered: Feb 2005
Vehicle: 91 300 E, 03 Jeep
Send a message via MSN to 1stW124 Send a message via Yahoo to 1stW124
RE: Power antenna mast fixed
Hmmm... looks like another item to add to my to-to-list. Thanks!
1stW124 is offline   Reply With Quote
Old 06-01-2005, 08:39 AM   #3 (permalink)
kgtbosco
Date registered: May 2005
Vehicle: 1989 300E
Also, clean with a light solvent and move the mast up and down until there isn't any more dirt, grime, rust , etc. Then apply the grease afterwards. Works great.
Ty
kgtbosco is offline   Reply With Quote
Old 06-01-2005, 12:21 PM   #4 (permalink)
Kestas
Vehicle: 95 E320 Cabriolet
Mine works fine. Do you guys suggest doing this as preventive maintenance?
This message written with 100% recycled electrons.
Kestas is offline   Reply With Quote
Old 06-01-2005, 12:53 PM   #5 (permalink)
kgtbosco
Vehicle: 1989 300E
Preventative Maintenance for those looking for more things to do to their car to keep it looing new! Other than that, if the mast is noisy or dirty this will fix it right up.
Ty
Old 06-01-2005, 05:32 PM   #6 (permalink)
drtung
Vehicle: E220 1994
FOr preventive sake, it seems reasonable to clean the mast monthly. The fact is that eventually dirts will accumulate enough into the mast after repeated retraction and extension. With such dirty air in our city, I will wipe the mast every 2 weeks...if I keep my words. [xx(]
Old 06-02-2005, 09:19 AM   #7 (permalink)
Yal
Date registered: Sep 2004
A good substitute to silicone grease is something called white lightning. Its a self cleaning chain lube used by cyclist. Cheap silicone grease will pick up dust and start to clog. This stuff doesn't do that. I wipe my antenna clean with it every 3 months and it stays put in heavy rain or snow with the antenna up.
If there is a bicycle store near you they'll have it.
Good stuff! It will stop the sound coming from your antennna in no time. If off road bicyclist use it you can be sure it will stand up to anything you throw on your antenna. You can put as much as you want on (not neccessary) and it will never clog
Yal is offline   Reply With Quote
Old 01-07-2006, 08:20 AM   #8 (permalink)
drtung
Vehicle: E220 1994
Eventually, the nylon part of the antenna mast broke one year later. Nylon fatigue after servicing for 12 years... :)
