I recently acquired a 1992 300TE 4matic wagon which is running well but RPMs on the highway seem high - about 3500 at 70 mph. I checked the fuel consumption on a recent interstate/secondary roads trip and got almost 24 mpg!. It definitely shifts through all 4 gears so it is either getting decent mileage even at these rpms or the tachometer is off - I did notice rpms were a bit over 3000 at 60 and bit under 4000 at 80. Is going to a lower diff ratio a big deal?
Originally Posted by EuroCoupe
The two main things that cause this is the 4 speed tranny and the gear ratio on the differential. The factory gears on the 300E are 3.07, the wagons have 3.27 so they will rev even higher at cruising speeds. A customer with a 300E came into my father-in-law's shop 2 weeks ago saying he had a tranny problem because he was pushing nearly 4000 rpm on the freeway and thought 4th gear wasn't engaging. After looking at the car we figured out it was fitted with a 3.67 differential! Great for acceleration but deadly for gas mileage. Bottom line, these motors can run and were made to run ALL DAY at 3000-3500 rpm. No worries, just keep an eye on temp gauge to make sure all is well. Or go to a longer gear ratio like a 2.87.
Man, this topic is old!
Do you have the original diff on the car?
__________________ Shady
I drive too fast to worry about cholesterol. My CarDomain corner
2005 Mazda 6i ATX (She aims to please)
2005 Mazda 6i MTX (gives V8s a run for their money)
1987 Mercedes 300E (sold. They sure don't make'em like they used to)
1992 GMC Typhoon (sold. A lost cause!)
2004 GMC Yukon (the wife's, can't touch it!)
This sounds just about right as these cars do not feature overdrive. Both my 124 and 126 have the M103 engine and these readings are within the norm i believe.
1988 300TE, 251,000 miles
1989 300SE, 89,000 miles
2000 E320 4matic wagon, 115k miles
id say that 24mpg for a TE 4MATIC is great. all wheel and four wheel drive cars generally get worse fuel economy. and the touring and coupe models all had a numerically higher (better acceleration and load hauling, poorer fuel economy due to higher engine revs at any given speed.) rear end ratio.
in my 2.6 liter 124 i avgd 25 mpg on a long (1070 miles each way) trip at an avg of 75mph. bear in mind though, that i had to go through quite a few mountian passes in colorado and some awesome canyons in southern utah. on the really steep climbs i dropped it into 3rd and ran at near 6000rpm to maintain my speed. when i got home and ran the numbers i was initially disappointed that it was that "low" but to avg 75 meant there was some 100mph plus driving, and all the mountain passes.
then a quick peek at fueleconomy.gov showed the EPA rating to be 23 and i beat that. not to shabby for a 17 year old car.
'O=00=O' BMW 2002. long live the legend.
