I have an E300D 24valve estate and it has just started to give the following problem. It starts fine and runs well but when it reaches about 78-80 degrees on the temperature gauge it loses power and almost dies. By taking it off load I can usually keep it running and it soon clears itself and runs fine again. I suspect there may be some king of sensor which is activated at this temperature which is failing or has failed. Any diesel experts any ideas/suggestions
This sounds like a fuel problem. I would change both of the filters and see what happens. You could also have a scan done at most local auto parts stores. They will be able to give you a code that can be translated for you...
Chuck
Chuck "You can't kill em"
'74 240D - 359,000 Miles (sold) • '76 300D - 350,000 Miles (sold)
'84 300CD- 280,000 Miles (sold) • '85 300D - 380,000 Miles (sold)
'87 300D - 275,000+ Miles • '87 300D - 175,000+ Miles (yes I have two)
'98 G320 - 150,000+ Miles (Official Range Rover Recovery Vehicle)
