» Site Navigation
» Other Sites
Old 12-28-2004, 06:46 AM   #1 (permalink)
CEorbust's Avatar
Date registered: Sep 2003
Vehicle: 300CE
M103: White smoke from engine breather hose
Today I unplugged the rubber hose from the air filter box while the engine was idling. Noticed a lot white smoke coming out from that breather hose. My friend told me my piston rings are bad and thus causing "blow-by". How am I able to determine this? Thanks for all advise. Happy Holidays!
CEorbust is offline   Reply With Quote
Old 12-28-2004, 08:51 AM   #2 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
RE: M103: White smoke from engine breather hose
how much is a lot? if it is really noticeable then yes, you may have a bad ring/blow by issue. I'd start by doing a compression test, then take it to someone that can do a leak down test.
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
Old 12-28-2004, 01:04 PM   #3 (permalink)
Date registered: Dec 2004
Vehicle: 400E, 500E, 560SEC, C240
Perform a compression test right off the bat.
You may want to consider switching to a thicker viscosity engine oil. Too thin an oil on a high mileage motor will cause the white vapor you described. Use MOBIL 1 15W 50 most MBZ techs. swear by this stuff.
89'300e
92'400e
92'500e
Redwood
400E 4.2
500E 5.0
560SEC 5.5
C240 2.6
redwood is offline   Reply With Quote
