» Site Navigation
» Other Sites
Old 12-22-2004, 11:45 AM   #1 (permalink)
Date registered: Dec 2004
93 300e Weeeeeeeeeerrrrrrrrr in the morning
I have a 93 300e. When I start it in the morning I hear a weeeeeeeeerrrrrrrr coming from the engine. After a few minutes of running it is gone. Does anyone know what this is?
I was told that the Poly Belt needs replacing, could this be the source of the noise? What does it cost to replace a poly belt? also are there any other items I should have replaced (because of duplicative labor) while they are replacing the poly belt?
Thanks
gmoney is offline   Reply With Quote
Old 12-22-2004, 02:06 PM   #2 (permalink)
alexnatt's Avatar
Date registered: Feb 2004
Vehicle: 1988 300TE 1989 300SE
RE: 93 300e Weeeeeeeeeerrrrrrrrr in the morning
I think I may have the same problem. I hear the noise while sitting in the cabin. It seams to come from behind the glove box. Almost sounds like radio static. Is this familiar?
alexnatt is offline   Reply With Quote
Old 12-22-2004, 02:11 PM   #3 (permalink)
Yal
Date registered: Sep 2004
gmoney - 12/22/2004 2:45 PM
Thanks
In may be your Air pump. The Air pump cuts in at start up. Its connected to the drive belts by a clutch which could also go bad.
It could also be that your belt tensioner has failed so your belt is loose and squeels on cold start.
Yal is offline   Reply With Quote
Old 12-22-2004, 02:15 PM   #4 (permalink)
Yal
Noise behind the glove box could be the tiny fan motor for the interior temp sensor opening located next to your interior light switch.
Sitting in the drivers chair look up next to the interior light on/off switch. You should see a vent. The fan pulls interior air into that vent to the sensor that adjust the climate control. The fan is located behind the glove box to the right.
Old 12-22-2004, 03:23 PM   #5 (permalink)
Date registered: Jan 2004
I would try Belt Dressing first.
And check if the belt is tight enough.
rostov is offline   Reply With Quote
Old 12-23-2004, 11:43 AM   #6 (permalink)
Thanks to all for responding. My noise sounds like it is in the front of the engine compartment, not near the glove box (which my car doesn't have a glove box). Will check the belt and air pump.
Old 12-26-2004, 08:31 PM   #7 (permalink)
Rafael Grullón's Avatar
Vehicle: 1997 E420 Sport
Recirculating exhaust pump!!!
Only works when cold. It disconects after warming up a little. Normal.
From silver star to silver star,
Rafael
Rafael Grullón is offline   Reply With Quote
Old 12-27-2004, 11:02 AM   #8 (permalink)
Thanks.
Old 12-28-2004, 02:25 PM   #9 (permalink)
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: 1991 560 SEC
Send a message via AIM to jhodg5ck
I'd disconnect the wire going to it.. Not really neccesary, ya know and no more noise:)
Jonathan
Blue Ridge Mercedes/AMG East
Offering Enthusiast Service, Restoration and Tuning.
Providing quality parts to all parts of the world.
Located in the Atlanta area
96 S600 Euro
91 560SEC ECE (for sale)
91 560 SEC 226/271 Undergoing TT conversion
86 560SEL AMG 6.0L 32V
89 300TE (Mosselman TT waiting..)
88 560SEC AMG Euro ECE
89 560SEC AMG mech. lifter/68K rpm conv.
87 Hammer 6.0L 32V
06 Z4 M Spec 6sp
jhodg5ck is offline   Reply With Quote
