Steering wheel freeplay on W124 - How much is ok? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-28-2004, 01:29 PM Thread Starter
Date registered: Nov 2003
Vehicle: 1987 230E W124
How much steering wheel free play should I permit on my car? What is the standard for W124s?
Lemmyb
1987 Merc W124 230E
1982 Merc W123 250
1981 Merc W123 300D
lemmyb is offline
post #2 of 8 (permalink) Old 09-29-2004, 03:35 AM
Storm's Avatar
Date registered: Jan 2004
RE: Steering wheel freeplay on W124 - How much is ok?
I don't mean to be rude but I think NONE is the answer to your question.
Storm is offline
post #3 of 8 (permalink) Old 09-29-2004, 04:03 AM
raz
Date registered: Feb 2004
Vehicle: E 250D 1994
Send a message via MSN to raz
over time it has a tendancy to get "worst", how can u stop it, or make it go away?
raz is offline
post #4 of 8 (permalink) Old 09-29-2004, 05:59 AM
sleepwalker's Avatar
Date registered: Apr 2004
Vehicle: Mazda 6
two inches is the maximum allowed free play.
larger than that, the worm gear needs adjustment. it's an easy job.
sleepwalker is offline
post #5 of 8 (permalink) Old 09-29-2004, 09:04 PM
Rafael Grullón's Avatar
Vehicle: 1997 E420 Sport
it's an easy job.
In fact it is an easy job for RH vehicles, but for LH is almost impossible unless you take out the inlet manifold or ,better yet, the steering box, because the adjusting screw is on top and there´s no way to reach it.
From silver star to silver star,
Rafael
Rafael Grullón is offline
post #6 of 8 (permalink) Old 09-30-2004, 01:54 AM Thread Starter
Fortunately my car is a right hand drive so i shouldnt have a problem. Thanks guys.
1987 Merc W124 230E
1982 Merc W123 250
1981 Merc W123 300D
lemmyb is offline
post #7 of 8 (permalink) Old 09-30-2004, 02:08 AM
Six_wheeler's Avatar
Date registered: Jun 2004
Vehicle: 1994 E320
Quoted: 76 Post(s)
Send a message via MSN to Six_wheeler
Two inches is way too much. I think it's more like 10mm max to either side. Before you go on adjusting the steering gear, check for damaged/worn out tie rod ends and pitman arm. Those will cause a lot of free play. Replace any worn parts. You just might find that your steering gear doesn't need adjustment after all.
Also, beware whether the "free play" is genuine or percepted. The steering feels like it has more free play with the engine running (power assist on) than when the engine is off. Also, wider tires can give you the ^perception^ of having more free play than usual.
Shady
Six_wheeler is offline
post #8 of 8 (permalink) Old 10-01-2004, 01:56 AM
Vehicle: Mazda 6
that was more precise.
