» Site Navigation
» Other Sites
Old 08-02-2004, 04:16 PM   #1 (permalink)
Vehicle: 1992 MERZ 400E
how do i install k-mac rear adjustable camber bushings?
its in the shop right now and they can't figure it out
not sure if i even have the right part now
sent messages to ksing44
left messages at k-mac in auss
if anybody has any information please let me know
thanks
menaceboy is offline   Reply With Quote
Old 08-02-2004, 11:55 PM   #2 (permalink)
Date registered: Jun 2004
Send a message via MSN to Six_wheeler Send a message via Yahoo to Six_wheeler
RE: how do i install k-mac rear adjustable camber bushings?
I suppose you have to replace the camber rod as a unit. Otherwise, you have to have the bushings pressed in.
Shady
Six_wheeler is offline   Reply With Quote
Old 08-03-2004, 03:25 AM   #3 (permalink)
ksing44's Avatar
I also sent you an email - I wish I had your nice grille
First, I have to say that I am not an expert. I had the parts installed by an independent mechanic.
On the front of the car, they call them control arm bushings. At the rear of the car, which is where the K-MAC bushings are installed, I think they call them subframe bushings. It is very difficult to remove the old bushings and the small tool provided with the bushings is useless. If you look at the suspension, you should be able to see how the new eccentric busing could move the rear wheel in and out. The smaller eccentric bushings are for rear toe adjustments, but the OE parts are already adjustable and do not need to be replaced.
If your mechanic doesn’t understand what to do, I think maybe you need a new mechanic. This is not an easy job and you will need a good alignment by a good mechanic when you are done.
Below is a picture and the link where I found the picture that shows exactly where to install the K-MAC bushings.
http://www.mercedesshop.com/shopforum/showthread.php3?s=&threadid=83062
I just couldn't give up on my 1995 E320.
I think it might be like always going back to that same bad relationship with an ex girlfriend.
You feel you love them too much, or you are just too stupid to know any better.
ksing44 is offline   Reply With Quote
Old 08-03-2004, 01:06 PM   #4 (permalink)
RE: I also sent you an email - I wish I had your nice grille
Hello,
just what advantage do those bushings offer exactly?
Shady
Old 08-03-2004, 01:25 PM   #5 (permalink)
thanks again ksing
polyurethane bushings over rubber
wear i believe?
not sure but all the pro's use it hehe
but these can adjust my rear camber cause i dropped my car and my wheels are /----\ squat
