Radiator light - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-26-2004, 08:32 PM Thread Starter
Date registered: Jun 2004
Radiator light
Can anyone tell me if the radiator light has anything to do with the flow rate of the water or the fact that it is rust colored??? The light comes on as soon as you start the engine even though the temperature gauge is well within range and not overheating. I thought maybe the thermostat was sticking or maybe it has a flow meter????? Any help would be welcomed before I go to the Benz mechanic....It's a 300E 1995 and runs cool and smooth even in 98 degree weather?????[:)]
willieg is offline
post #2 of 5 (permalink) Old 07-26-2004, 09:39 PM
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
RE: Radiator light
the rad light is just a level indicator. it's located in the expansion tank. as for the rust color, it's either rust, oil or some kind of sealant like bars leak. also possible is somebody added pink 5 year. this added to green makes brown. i would flush,flush, replace thermo and fill with mercedes a/f which is clear. be sure it's flushed well cause brown and clear make brown...keep an eye on it....kevin
BENZDOC is offline
post #3 of 5 (permalink) Old 07-27-2004, 08:01 AM
Vehicle: 95 E320 Cabriolet, 106K
RE: Radiator light
Are you sure the rust color is unusual? I too thought couldn't figure out what was going on with the cooling fluid when I first took ownership of my Benz. When fresh, the coolant has an amber color to it if the proper coolant was put into the system. It is highly recommended to use only MB antifreeze or Zerex G-05 in these cars.
95 E320 cabriolet, 121K
Kestas is offline
post #4 of 5 (permalink) Old 07-27-2004, 09:16 AM
Date registered: Jul 2004
Vehicle: 1989 300E W124
Send a message via AIM to jmvellis
RE: Radiator light
http://
Really? I have been using Penzoil AntiFreeze coolant and have had my car for about 6 years now and havent had any problems. Where would i find MB antifreeze if i should be using it?
jmvellis is offline
post #5 of 5 (permalink) Old 07-27-2004, 09:49 AM
RE: Radiator light
MB coolant is dealer-only. Zerex G-05 is essentially the same thing (and approved for MB engines) for almost half the price.
I don't know about the suitability of Pennzoil's Antifreeze. Perhaps their web site can answer this question.
Any problems with using the wrong antifreeze generally only show up with long term usage.
Kestas is offline
