Did anybody have knowledge about a full check up of the vacum system.What should I do. I suspect a vacum leak that is making tha trany to shift hard and also the door locks to act a bit delayed.Also the vents are acting a bit abnormal.What tools I shoud use? What is the normal value of the vacum in the system(mm Hg)?
to test the system you will need a hand held
Vacuum Pump, Hand Operated, With Presure Gauge $25.50
VAC-54174
http://images.google.co.uk/imgres?imgurl=http://www.cynmar.com/images/VAC-54174.jpg&imgrefurl=http://www.cynmar.com/default.php%3FcPath%3D122_257&h=188&w=149&sz=8&tbn id=y9UPeBOgRg0J:&tbnh=95&tbnw=76&start=69&prev=/images%3Fq%3Dvacuum%2Bhand%2Bpump%26start%3D60%26h l%3Den%26lr%3D%26ie%3DUTF-8%26sa%3DN
and not a bad price[8D]
