» Site Navigation
» Other Sites
Old 06-14-2004, 01:27 PM   #1 (permalink)
Date registered: Jun 2004
Vehicle: 300 E 1987
Send a message via MSN to mayukh_coolest Send a message via Yahoo to mayukh_coolest
Non functioning AC and cruise control
Hi all,
Thanks to this wonderful forum I got my car rid of the problem of the coolant puddle .....
it was the water pump .....the labor costs were exorbitant but at least it is fixed ...........
I also have a few more problems :
1) The air conditioning does not work , how ever the heating does !
2) The cruise control does not work at all, I have tried it a zillion times and it does not work at all.
3) I hear quite a lot of sounds which i think are coming from the front suspension and it is getting increasingly louder any ideas how i can check the suspensions front and rear of the car ,
any advise will be greatly appreciated
thank u again all for helping me solve my previous problem !
regards
mayukh
mayukh_coolest is offline   Reply With Quote
Old 06-14-2004, 04:47 PM   #2 (permalink)
Date registered: May 2003
Vehicle: 1990 190E 2.6
RE: Non functioning AC and cruise control
First, be sure all your fuses are intact; look closely, some may seem OK but actually be busted.
1) May just need a recharge. You'll want to start there and check for leaks.
2) Cruise control amp?
3) Get the car on a lift and look under there. Pay close attention to all the rubber bushings and ball joints. Make sure your springs are OK (probably) and your shocks/struts still function properly (may or may not)
"I am serious, and don't call me Shirely"
Chamorro is offline   Reply With Quote
Old 06-14-2004, 06:15 PM   #3 (permalink)
GwagenLover's Avatar
Vehicle: 02 G500 & 05 ML350
The cruise control on my 124 was not working and the cause was a bad relay. Cost $24 The A/C I am not sure of.
Visit my website: www.oldsalemhomes.com and see what it is like living in a histoic town
GwagenLover is offline   Reply With Quote
Old 06-14-2004, 07:20 PM   #4 (permalink)
Date registered: Dec 2002
Gwagenlover,
I have the same problem. Where is the relay located?
Thanks,[?]
Donwo
1989 560SL
1998 E320
donwo is offline   Reply With Quote
Old 06-15-2004, 09:16 AM   #5 (permalink)
Vehicle: 300 E 1987
Thank u for the hints but I know nothing abt cars so pls tell me where I can look for the relays , amplifiers and the fuses ! I would be very greatful the make is a 1987 300E
Old 06-15-2004, 09:16 AM   #6 (permalink)
Vehicle: 300 E 1987
Old 06-18-2004, 05:33 AM   #7 (permalink)
Vehicle: E320 wagon
On the air-cond, see if the clutch engages on the compressor, you may have to bypass the pressure switch safety. Then watch the sight glass for flow and a change in temp. on lines in and out of the compressor / in the car. That way you will have an idea on what could be broken and not go for the $1000 dollar rebuild.
Uboater is offline   Reply With Quote
Old 06-18-2004, 05:58 AM   #8 (permalink)
teky's Avatar
Vehicle: chris
http://www.benzworld.org/publications/pub.asp?id=246
fuse and relay locations, upps one of em is upside down sort it later[:)]
teky is offline   Reply With Quote
Old 07-21-2004, 07:22 AM   #9 (permalink)
Vehicle: 300 E 1987
Thank u so much TEki that was really helpful !
