My car cranks too long till the engine starts when its cold,but when i stop the car and start it again it starts from first crank very fast.So what could be the problem?starter?
The cold start valve is supposed to inject extra fuel into the intake for easier starting when the engine is cold. It injects more or less fuel depending how cold the engine is... it is not supposed to operate when the engine is warm/hot. If it is malfunctioning, it can cause problems starting both when hot and cold. Ie. it does not inject enough fuel when cold or injects too much when hot.
It is located underneath the air filter housing around halfway along the length of the engine, maybe between the third and fourth cylinder... It has a blue plug I think... Do not quote me on that though... cannot remember exactly.
Do not have a pic. Can post one next week, when I borrow a friends digital cam. Maybe someone else can post one here for you sooner Inblues...
Thank you Cheeryvampire.
I have sometimes problem with cold start, but not all the time.
Is there a way to check this valve somehow to see if it is operating properly or should I just buy new one?
hi
ur problem its easy and to slove it
the all problem from ur self(starter)
when u car is hot the starter start good
but when cold the starter is diffucult to start.
change u starter ( self ) .
thats all
When the engine is cold you can test the valve by...
-Pulling it out
-attaching only the fuel line
-turning on the ignition without starting the engine
-the valve then should not be ejecting any fuel
-reattaching the electrical line
-see if the valve spits a steady amount of fuel out, may want to get a cloth or jar to eject the fuel into
-disconnect the electrical line, the fuel flow should stop completely
I think I have listed all the steps, Inblues. Try testing it before purchasing a new one, they are somewhat expensive. For anyone else out there, please feel free to add anything that I might have missed.
-CV
PS: Sako83, based on your listed location I do not think a cold start valve will do you any good. They are more for use when starting below freezing temperatures.
I went to electrician and he removed the starter, cleaned it and replaced the front part of it.Now its better but also its not starting the engine from the first crank,its taking nearly 4 sec to start the engine.Is it normal?
no not normal
put tell me first what happen after u start engine
i mean whats the reading in rpm gauge
give me nummber more than 10 or less than 10
next step and whats last time u make tune up
for ur car ?
if u answer my question i give answer why u late start ?
[8D]
