Old 01-24-2004, 10:30 AM   #1 (permalink)
Inblues's Avatar
Date registered: Oct 2003
Vehicle: 1991 300 CE
Idle control valve
Can someone please tell me or has a pic, where idle control valve is located on 300 CE 24V.
Thank you in advance..
Inblues is offline   Reply With Quote
Old 01-27-2004, 04:30 PM   #2 (permalink)
Inblues's Avatar
RE: Idle control valve
I have found a pic of it but now need info where is it located on the car (or engine)....
Please, any help would be appreciated
Old 01-28-2004, 01:22 PM   #3 (permalink)
Date registered: Nov 2003
Vehicle: Slow benz
I don't know about your car, but I replaced mine on a 88 300E and it was located under the air filter housing. You'll see it once you take off the air filter housing. I would check the rubber hoses that connect to it for cracks as well (mine needed to be replaced). Hope this helps.
blackbenzz is offline   Reply With Quote
Old 01-28-2004, 01:52 PM   #4 (permalink)
Inblues's Avatar
Thank you blackbenzz I will check for it later on tonight....
And if I can ask why was the reason for youto change it? What were the symptoms before you changed it?
Old 01-29-2004, 12:36 PM   #5 (permalink)
Vehicle: Slow benz
The original problem was rough idle and rough start and it was sluggish. The idle control valve (and hose)fixed both problems. But this was after I replaced almost everything else :(
