300E won't start - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 01-15-2004, 08:20 PM Thread Starter
barry_s_u's Avatar
Vehicle: 300SD, 300E, SLK230
300E won't start
Just happened today. Can hear fuel pump a-buzzin, but will not engage starter. Already tried starting in Neutral (neutral switch problem). Didn't help. Could still be the problem. Other most likely culprit is starter relay, I suppose. Any other suggestions?
BTW, turned on lights while trying to start in case the starter was shorted or locked and didn't see the light's dim at all. Almost imperceptable noise when trying to start (quiet thunk). Bad starter relay?
Barry
1998 SLK230
1993 300E 3.2 (totaled in 2008, collision with deer)
1984 300SD (donated to technical school in 2010)
barry_s_u is offline
post #2 of 10 (permalink) Old 01-15-2004, 08:27 PM
BenzWorld W124 Host
Tubs300E's Avatar
Date registered: May 2003
Vehicle: 1993 300E 3.2L 24V
RE: 300E won't start
Wiring harness possibly? I know I'm waiting for mine to expire. Do you have a updated OVP relay?
-Tubs
W124 Forum Host
1993 Mercedes-Benz 300E Arctic White over Palamino Leather
W124.032 Chassis M104.992 24V Engine
217 Horsepower @5500RPM
229lbs-ft Torque @3750RPM
Aftermarket Modifications
-TYC Euro-Spec Headlamps
-DEPO Clear turn signal indicators
-Kenwood KDC-217S CD Player AM/FM Tuner Headunit
-Chrome Exhaust Tips
-Auxiliary fog lights and driving lights
-Tinted windows: 22.7% on the back 5 and 33% on the front 2
Tubs300E is offline
post #3 of 10 (permalink) Old 01-16-2004, 07:21 PM
Chupper's Avatar
Date registered: Sep 2002
Vehicle: 2008 Xterra Off-Road
Try turning the car over in Neutral instead of Park. Currently with my car, it only starts in neutral because of a messed up Neutral Safety Switch.
Chupper is offline
post #4 of 10 (permalink) Old 01-16-2004, 08:34 PM Thread Starter
barry_s_u's Avatar
Chupper,
Tried that already. Mentioned it in my original post. Am going to bang the starter with the handle of a hammer and see if it frees up the starter solenoid. I suspect that's the problem. Currently the car is outside because I'm repairng my 30 year old IH Cub Lo-Boy tractor in one half of the garage, and the other half has the 300SD in it.
Now if the wind chill would just rise a little above -10, I'd be fine.
Does anyone know how hard the Neutral switch is to get to in case I need to go after it?
Thanks, people!
Barry
1998 SLK230
post #5 of 10 (permalink) Old 01-16-2004, 09:11 PM
janos_z's Avatar
Vehicle: 1989 560SEL
you mentioned the starter relay, but what about the starter itself?
Janos
Current:
-1989 560SEL
Past:
-1993 400E
-1993 500E
-1994 E320 wagon
-2007 C230
janos_z is offline
post #6 of 10 (permalink) Old 01-16-2004, 09:44 PM
Chupper's Avatar
Woops, sorry, I'm worn down by life [:(]
I think I've heard that sometimes the neutral safety switch won't let the car start in Neutral or Park, so yea...
Other than that I can only infer its not the starter. It's weird that it would just die like that. But other than the fuses and the switch, I don't know what to say.
Good luck
Chupper is offline
post #7 of 10 (permalink) Old 01-16-2004, 10:31 PM
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
By the master cylinder, there is a 3 wire plug. The center purple is the "S" terminal of the solenoid. Juice it up with a jumper from the + of the bat. If it cranks, the problem is with the ignition switch or the neutral safety switch. (unless you have an aftermarket alarm, 'cause they usually interupt the start circuit).If it did crank, make sure its in park, turn key to position 2,(all lights in cluster on)and crank. It will start. If it does not crank, its: dead bat, bad starter, or bad or loose connection.
BENZDOC is offline
post #8 of 10 (permalink) Old 01-18-2004, 04:52 AM Thread Starter
barry_s_u's Avatar
Put +12 0n the purple pin (first did that on the socket and got nothing). I could hear what bust have been an attempt to pullin in the starter solenoid but, no-go. Ordered another starter from Importec.com. Will try (when I can jack up the car) to tap the starter to see if something's just stuck.
My stone driveway isn't conducive to jacking the car up and crawling under the car when it's 20 degrees with a 10 mph wind. I'm going to try to get it in the garage later today. Damn thing is heavy, though, and we're having a snow/rain/ice "event" now.
Thanks for the help!
Barry
1998 SLK230
post #9 of 10 (permalink) Old 02-17-2004, 09:04 AM Thread Starter
barry_s_u's Avatar
Bad Starter confirmed. Found loose (-) terminal at battery after jump-starting. thought that was it. Car then left us stranded after a wedding on Sunday (it was a lot colder). Came back the next day and whacked the starter solenoid with the handle of a hammer (for reference purposes the starter solenoid sits on top of the starter on the left side of the engine just in front of and below the oil filter on the 3.2 engine). Engine started, I took it home and replaced the starter. Again for reference:
2 - 17 mm bolts hold the starter on; bottom one is easy to get to, top one takes a lot of patience[:(!]! The bolts go through the bell housing into the threaded holes in the starter.
1 - 13 mm nut and spring washer holds the large battery terminal on
1 - 10 mm nut and flat washer hold the solenoid lead
Starts beautifully now!
Barry
1998 SLK230
post #10 of 10 (permalink) Old 04-12-2004, 11:12 PM
Date registered: Jan 2004
RE: 300D won't start
I have a problem with my 1987 300D I try to start it and nothing happens it won't even turn over i was told its probably ur ignition switch or neutral switch but i put a wire to the postive bolt and it started but won't start from the ignition i don't know what to do
wessok is offline
