» Site Navigation
» Other Sites
Old 12-26-2003, 04:03 PM   #1 (permalink)
Date registered: Aug 2003
How do I know if my wiring harness has been replaced?
I recently purchased a '95 E320 wagon. The car came with a Starmark warranty. I would like to get the obvious problem areas taken care of while the car is still under warranty--things like the wiring harness and head gasket.
How do I know if these things have already been replaced? If they haven't, do you think the dealer will replace them under warranty? Are there any other problem areas that I should get fixed on the dealer's dime? Thanks.
Chris
reed is offline   Reply With Quote
Old 01-01-2004, 02:45 PM   #2 (permalink)
Date registered: Jan 2004
RE: How do I know if my wiring harness has been replaced?
I'm assuming your wagon was not serviced at the same dealer you purchased it from. If this is true, find out where it was serviced and have them search the service history. Simply check your service records or booklet for the servicing dealer
bendz4benz is offline   Reply With Quote
