W123 differential - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-28-2017, 05:51 AM Thread Starter
Date registered: Feb 2007
Vehicle: MERCEDES 230 MODEL 1979
Send a message via MSN to MR_BENZO
W123 differential
Hii Geeks,
I had recently swap my M115 engine to M102 985 engine with 5 speed manual trans, I didn't swap my differential and still using my old one for the M115 engine, I can feel that the acceleration is not that good and the car top speed also I think is affected 170 KMH which I think that the differential is the main cause so I need you confirmation on this, also I need you help to know what is teh best differential ratio to have as per my knowledge it is 3.69 is this correct
Regards,
MR_BENZO is offline
post #2 of 10 (permalink) Old 04-28-2017, 06:42 AM
Date registered: Aug 2011
Vehicle: Diesels om616 -> om606
Quoted: 58 Post(s)
do you want better acceleration?
the only difference between your current fivespeed and the earlier fourspeed (besides smaler geardifferences in first to third gear) is that the new one has a fifth gear that lowers the rpm further.
the m102 in the s123 that came with a fivespeed (i had the 2.0 liter carburator in one car) had a finaldrive ratio of 3.58, and that would make the car a bit more sluggish than your current 3.69.
I would not say that the differential is the main cause, you are in about the same gearratio as the engine had stock (both in w123 and w124 chassis)
Since you have the 2.3 liter KE-jetronic version you ought to have some power in the engine, and i would not suggest going for a 3.92 differential that would be the next step for quicker acceleration.
I would guess the engine is the culprit, either something isnt working as it should, the KE-jetronic isnt setup correctly or your exhaust might be clogged (a catalysator that is old and limits flow can seriously slow an engine down)
you ought to have some power, 97kw (about 130hp) moves the car quite okay, i would look at the engine.
or do you feel it revs itself to much?
then there is options. but "acceleration" gets less good in that case.
Daily: w123 om602 7.5mm 200whp
special/projects/storage: 20 cars +
mbturbo.com
swampmonkey is offline
post #3 of 10 (permalink) Old 04-28-2017, 08:37 AM
Stretch's Avatar
Date registered: Jul 2011
Vehicle: 1981 W123 300D non turbo, 1992 190E 1.8 <=> 2.0
Quoted: 554 Post(s)
With a "low" top speed and a sluggish pick up I wouldn't suspect gearing just yet
1992 190E 1.8 <=>2.0 201.018 => Daily driver
1981 300D (non turbo) 123.130 => Project car - stripped to the bone
1965 Land Rover Series 2a Station Wagon => CIS recovery therapy!
Free and legal FSM download => Ask for help if you get stuck!
Don't leave that there I'll take it to bits
Stretch is offline
post #4 of 10 (permalink) Old 04-28-2017, 08:51 AM
Quoted: 58 Post(s)
the acceleration should not be affected at al, since in theory you have an engine with much more power.
besides in fifth gear, where it might be slower than fourth paired to the old engine (witch then was the top gear)
by "top speed is affected" what do you mean? its worse with the new engine compared to the old? or compared to the old car that engine was in? (the w201 has lower wind-resistance, and is lighter, so it would not be strange if the car feels a tad slower now)
Here you have a list of different differentials/finaldrives and what fits the w123
differentials, gear-ratios and compatibility | Mercedes-Benz turbo
mbturbo.com
post #5 of 10 (permalink) Old 04-28-2017, 01:01 PM
Stretch's Avatar
Quoted: 554 Post(s)
What I should have made clearer is that (generally speaking for W123s in particular) with gearing you can either be a super hero at the traffic lights but go deaf due to screaming engines at motorway speeds or have a much quieter life at motorway speeds but watch cyclists / mobility scooters burn you off at the traffic lights...
...the problem described in this thread sounds to me to be more related to poor engine performance than gearing (at the moment - based on what's been said so far)
Stretch is offline
post #6 of 10 (permalink) Old 05-02-2017, 01:25 AM
PlaneCrazy's Avatar
Date registered: Oct 2010
Vehicle: '86 W123 200, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
Quoted: 374 Post(s)
The M102 2.0lt carb had a 3.69 diff, same as the M115 2.0lt, M115 2.3lt, M123 2.5lt I6, and 240D
The M102 2.3lt fuel injection engine sometimes had a 3.69, sometimes a 3.58 diff. The 280E sometimes had a 3.58, sometimes a 3.46 diff.
Here in South Africa we typically had the 2.3lt M102 with a 3.69 diff and 4-spd manual, or 3.58 diff and automatic, to compensate for the high and dry climate.
Originally Posted by MR_BENZO View Post
Hii Geeks,
Regards,
The M102 was a major improvement over the M115 in terms of efficiency and fuel economy, but was never going to have a massive performance increase. MB intended for the six-cylinders to be the more sporty variants. The performance you mention seems to be typical and correct.
W202 C250 Diesel, OM605 NA engine, 5-speed manual
1986 200, OM617 NA engine, 5-speed manual, rev counter
Donkey, not gone, never forgotten...
PlaneCrazy - it's more than a name, it's a life choice!
QUOTES FROM CONSTERNATIUS:
"Inside every small problem is a big problem screaming to get out."
PlaneCrazy is offline
post #7 of 10 (permalink) Old 05-02-2017, 01:52 AM Thread Starter
Hello all,
I don't know my current differential ratio that I use "For the M115", I believe that the ma102 2.3 differential ratio should be 3.69 I will check my current one and will update.
If it is not the differential that is affecting my top speed, what else I should suspect and how to test.
Regards,
MR_BENZO is offline
post #8 of 10 (permalink) Old 05-02-2017, 02:04 AM
Quoted: 58 Post(s)
hmm, i looked at a 200gasser carb with automatic, and it had a 3.58, and im atleast 80% certain that was the same ratio i had on the 200T s123 fivespeed i have. (before it got the 2.47LSD it has now) might be a regional difference, in sweden the 240TD came only with 15" steel, and not 14" for example.
anyhow, the difference between a 3.58 and a 3.69 is not much, so little that i would not consider a swap "worth it"
@TS, i would look at the engine, as good as you can, that it performs as it should, are your exhaust in good condition, no catalysator that is clogged? is the timing correct, fuelpressure, have you had the exhaust "tested" that Lambda/HC etc values are correct?
the 2.3 is a rev-happy engine, down low torque isnt that much due to ratio bore/stroke, but at 3500rpm somewhere it should be happier,
mbturbo.com
post #9 of 10 (permalink) Old 05-02-2017, 02:36 AM Thread Starter
Hiiii, Regarding the exhaust I have a brand new one installed with the engine, I dont also have a lambada sensor, fuel pump also is a brand new bosch pump so I think the fuel pressure is ok, regarding the timing can anyone tell me detailed steps on how to check.
Regards,
MR_BENZO is offline
post #10 of 10 (permalink) Old 05-02-2017, 02:55 AM
PlaneCrazy's Avatar
Quoted: 374 Post(s)
It may well be regional. Here in South Africa I've never come across a M102 2.0lt with anything but 3.69.
The car that donated its engine to Donkey was originally a 280E 4-spd manual, with a 3.58 diff (The previous owner did the conversion from M110 to OM617). I drove that car a good long while in order to decide which of the two I would keep and which I would sell. Then I decided to keep Donkey. I installed the OM617 engine (still with a 4-speed manual) in Donkey, keeping her 3.69 diff and speedo, becuase I also didn't consider the 3% loss of speed worth the trouble.
It made a difference.
3% less top speed also meant 3% more revs per km travelled. It meant 3% more torque to the wheels. Donkey was much livelier with the same 300D engine than the donor car was. Their specification levels were the same, so their final masses were similar. Surprisingly, the fuel consumption wasn't affected much between the two. (Of course, the fuel consumption was greatly affected on Donkey by the conversion from OM616 to OM617. But I've mentioned that enough times elsewhere on this forum.)
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
