W123 with a standard Trans? - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 05-23-2016, 04:24 PM Thread Starter
Date registered: May 2016
I am darn sure you could get these in Europe but here in North America?
I have looked for a while and not found any.
Anyone on here seen one over the years?
catimann is offline
post #2 of 17 (permalink) Old 05-23-2016, 04:40 PM
Date registered: May 2014
Vehicle: 1988 300e 75 300d 74 450sl
Quoted: 191 Post(s)
There is a 83 with four speed on sacramento craigs list right now
rollin560 is offline
post #3 of 17 (permalink) Old 05-24-2016, 06:53 AM
ollo's Avatar
Date registered: May 2009
Vehicle: S430 93K; E420 243K; 240D 242K
Quoted: 65 Post(s)
Most common in the 240D model, only a few made in the 300D N.A., and all of the turbodiesel models were automatic far as I know. Don
John 5:25
ollo is offline
post #4 of 17 (permalink) Old 05-24-2016, 05:27 PM Thread Starter
Ok I'm a newbe here and to MB but considering they all share the W123 chassis will an 83 4 speed fit in a 80 300CD? Or for that matter with turbo diesel?
Is there a web site that I can look up this info?
Thanks
catimann is offline
post #5 of 17 (permalink) Old 05-25-2016, 05:53 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 518 Post(s)
Mercedes has no records of transmission types installed.
Over on W116 they have been polling to see what exists in those cars.
question for statistical maniacs
Perhaps you could infer something from this.
rumb is online now
post #6 of 17 (permalink) Old 05-26-2016, 11:13 AM Thread Starter
I was thinking more as to what different options came with these cars.
catimann is offline
post #7 of 17 (permalink) Old 05-26-2016, 08:39 PM
Smorrow's Avatar
Date registered: Sep 2015
Vehicle: 1982 300d four speed
Quoted: 32 Post(s)
4 and 5 speeds were available, however 5 speeds are very rare. (I don't know much about gasoline W123's) The 4 speed gearbox was only available for 240d's and 300 N/A engines and I believe the smaller 200d and 220d W123's. The 5 speed was optional for any non turbo'd W123 past 1982, however this was in Europe only. There never was a production turbocharged W123 with a manual transmission.
Smorrow is offline
post #8 of 17 (permalink) Old 05-26-2016, 09:17 PM
LostInTime's Avatar
Date registered: Oct 2013
Vehicle: 07 E350, 80 240D 4 speed, 90 300SE, 87 260E, 87 190E 2.3-16 5 speed.
Quoted: 633 Post(s)
LostInTime is offline
post #9 of 17 (permalink) Old 05-27-2016, 04:30 AM
VON
VON's Avatar
Date registered: Apr 2004
Vehicle: 1973 416 Doka, 1978 416 Doka, 1980 416 Doka..... Help me, I can't stop buying them!!!
Quoted: 136 Post(s)
My son drives a 85' 300D that is a Euro car that was originally non turbo and a 4 speed. Now has a 5 speed with the turbo motor. It is a blast to drive, and the standard transmission really wakes up the car!
Von
Fairport, NY
1973 Unimog 416 Doka
1980 Unimog 416 Doka
1984 Euro 380SL
1985 300TD Estate wagon
(I really need to stop buying these things!)
http://vonsmog.com
VON is offline
post #10 of 17 (permalink) Old 05-27-2016, 06:36 AM
Date registered: Aug 2011
Vehicle: Diesels om616 -> om606
Quoted: 58 Post(s)
the turbo never came with a maunual gearbox from the factory afaik.
as a swede (northern europe)
about half of the w123s is automatic, but the smaler engines a lot came with manual transmissions.
the fivespeed fitted to the om617/m110 engines are extremely uncommon, (both as a ironbox in the w115/w114 and early w123s) and as a whole-alu 717.400 gearbox on the later.
the 200/200T/230E/230TE m102 (witch you US people never got afaik) is the most common with fivespeed over here, the gearbox in that one is a 717.401 and made by getrag, but if you have a regular m102 with automatic or fourspeed, any fivespeed from a w124/w201 will fit directly to the engine, and just need some driveshaft and shifter fix.
Know of people over here that has done the fivespeed swap on their automatic or 4-speed m102 w123s.
the m102 doesnt have the starter on the same side of the engine as the rest of the w123 engines, and thus, isnt a compatible gearbox with the diesel/m110 engines etc, it is however compatible to the w124/w201 engines.
since manual gearbox availability is pretty scarce for the US-w123s, and the w124 engines have a lot, a pretty deacent option could be to fit a w124/w201 m102 or m103 engine in your w123, aswell as a fivespeed gearbox. thats what i would do. or the om602/om603 engines with the same type of fivespeed.
if going down the route of a fivespeed, do fetch one with a dual-mass flywheel setup, (different gearboxes for different flywheels)
it gives a lot smoother ride, swapped on my om602 turbo w123 from a single-mass setup to a dual-mass setup, and its a whole other ride where the noises, shakes etc dissapeared.
the gearboxes from w202 and w210 fits those w124 engines to, but lack the mechanical speedometer, and thus requires extra work if you want the speedometer to work.
Mercedes manual transmissions | Mercedes-Benz turbo
the 717.401 w123 gearbox is what i run behind the om606 turbo equiped w123..
the 717.430 the single mass i broke behind the om602 and the dual-mass setup 717.412 what i have know
Daily: w123 om602 7.5mm 200whp
special/projects/storage: 20 cars +
mbturbo.com
swampmonkey is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
