Dieselmeken is now selling MW pumps with 8mm elements - Page 3 - Mercedes-Benz Forum
post #21 of 27 (permalink) Old 10-05-2015, 07:02 AM
Pirublues's Avatar
Date registered: Feb 2014
Vehicle: '79 240D
Quoted: 225 Post(s)
Originally Posted by swampmonkey View Post
do it!
would be very interesting, what mods do you have?
what mpg, and how long have you driven?
Look at my sig for mods. I can get about 35 highway and about 28 mixed/city. About 3 years running off these mods. I really need a 5th fear though, cruising at 80 on the highway gets pretty loud.
-1979 Mercedes Benz 240D: OM617, 4spd, Garrett VGT, A2W IC.
Pirublues is offline
post #22 of 27 (permalink) Old 10-05-2015, 03:04 PM
Date registered: Aug 2011
Vehicle: Diesels om616 -> om606
Quoted: 58 Post(s)
teh 240d with a 617a in it?
how much boost? how do you controll the VGT turbo? (variable geometry) right?
did you swap from the stock 240d differential? if not, i absolutely understand why you need a fifth :P
i missed the fifth gear in my w115 with a turbo617 in it and a 2.65LSD differential :P
and accidently looked for the sixth gear in a 2.47 differentialed w126SEC with a om605turbo in it :P
Daily: w123 om602 7.5mm 200whp
special/projects/storage: 20 cars +
mbturbo.com
swampmonkey is offline
post #23 of 27 (permalink) Old 10-06-2015, 07:53 AM
Pirublues's Avatar
Vehicle: '79 240D
Quoted: 225 Post(s)
15psi
Vacuum actuator is used to control the turbo.
The stock 240d differential is in the car. I have a different one that I haven't installed yet. My OM617 if from a 300CD Turbo.
post #24 of 27 (permalink) Old 10-06-2015, 08:53 AM
Quoted: 58 Post(s)
Originally Posted by Pirublues View Post
15psi
oh, get a 3.07 in there asap :P
or do you acctualy use the first gear? i run a 2.88 in a 240dNA and think that is pretty good, one shifts out of first as soon as i get roling anyhow :P
differentials, gear-ratios and compability | Mercedes-Benz turbo
mbturbo.com
post #25 of 27 (permalink) Old 10-06-2015, 09:10 AM
Pirublues's Avatar
Vehicle: '79 240D
Quoted: 225 Post(s)
Yeah the first gear is used a lot. Maybe the rear diff I have sitting in the garage is a 3.07. I'll have to check out the part number.
post #26 of 27 (permalink) Old 01-27-2017, 08:53 PM
Date registered: Mar 2006
Vehicle: 1982 300D
Quoted: 75 Post(s)
Two years later, they have a 7.5mm MW on an actual engine.
1982 300D
4-speed manual, maxed MW-Pump, Sachs-Performance modified clutch, Holset HE221W, straight pipe exhaust, A/W intercooler, 2-stage W/M injection, W115 intake manifold, electric radiator fan, 2-Micron Baldwin BF7591-D fuel filter, Webasto TSL-17 auxiliary hear, W126 Gen-II front slotted brakes, battery relocated, skidplate, 15mm rear sway-bar
147HP, 220lb-ft at the rear wheels
2006 Honda Rebel Diesel
Kubota OC95, Comet 40C/44D CVT, 100mpg
Forcedinduction is offline
post #27 of 27 (permalink) Old 02-05-2017, 10:02 PM
Desert Panther's Avatar
Date registered: Feb 2012
Vehicle: 1978 300 CD, 1985 300 SD
Quoted: 4 Post(s)
Question
https://www.youtube.com/watch?v=_cIl-F7PqPA
any idea of the approximate cost to have this done to the 617 pump?
Desert Panther is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
