My 1977 240D died need help!!!! - Mercedes-Benz Forum
post #1 of 24 (permalink) Old 01-08-2014, 03:23 PM Thread Starter
Bev
Date registered: Jul 2006
Vehicle: 1977 Mercedes 300D and 240D and 1986 420 SEL
Quoted: 13 Post(s)
My 1977 240D standard was running great and always has until now. I came home and there was stuff in the driveway so I parked in the road and turned it off so I could move everything in the driveway. I went back 5 minutes later to pull it in and the car is dead when you turn the key to start it. The glow plug lights up on the instrument panel and I have power but when the light goes off and I turn the key to start NOTHING. what the heck happened? All the connections to the starter look good and there has never been an indication that the starter had a problem. Anyone have an idea whee to start?
Thanks
Bev
Bev is offline
post #2 of 24 (permalink) Old 01-08-2014, 03:31 PM
gatorblue92's Avatar
Vehicle: 1977 W123.123 1991 W124.090
Quoted: 366 Post(s)
Try to start the car in neutral.
1977 MB 240D 4 speed 142K - Long term project car.
1991 MB 300TE 5 speed 271K - Back on the road!
2014 Honda CR-V 33K - Wife's DD
2015 Ford F150 5K - My DD
1979 MB 280E 90K - Sold
1983 MB 240D 238K - Scrapped
1984 MB 300D 347K? - Sold
1987 MB 300E 5 speed 258K - Scrapped
1993 MB 400E 130K - Sold
1995 MB E320 - Sold
gatorblue92 is offline
post #3 of 24 (permalink) Old 01-08-2014, 03:43 PM Thread Starter
Bev
Quoted: 13 Post(s)
It doesn't matter if it is in gear or neutral, I get nothing when I turn the key.
Bev is offline
post #4 of 24 (permalink) Old 01-08-2014, 03:59 PM
TimmahW123's Avatar
Date registered: Aug 2009
Vehicle: 1991 Mercedes Benz 300D 2.5T, 270,000 miles & counting
Quoted: 30 Post(s)
Pull off your battery cables and clean them and your battery terminals with a wire brush and some Coca-Cola (or off brand Cola) until they are nice and shiny. Put them back together and try to fire the car up. If that doesn't work, see if you can get a jump start or push start (have someone push the car while you are in second gear, when you get up to about 10 MPH, pop the clutch and it should crank assuming its warm)
Sounds like you MAY have a bad cell or 2 in your battery, if you can get it started drive it to an Advance Auto or Autozone, they can test (FOR FREE) your charging system and battery for you and tell you what you need to do.
DO NOT SHUT THE CAR OFF when you get there. Being a diesel it will stay running with a dead battery however, you're going to need it running for them to run the charging system test.
Tim
Current Rides
1982 Mercedes Benz 240D MT ~ Daily Driver
1991 Mercedes Benz 300D 2.5 Turbo
2006 Dodge Grand Caravan ~ Family Truckster
If there is one car that has earned my respect above any other, it would be the 240D. My stress just melts away as that diesel sings it's sweet song, mile after mile. Its therapeutic in a way, to know that she sings again because of me.
TimmahW123 is offline
post #5 of 24 (permalink) Old 01-08-2014, 05:09 PM Thread Starter
Bev
Quoted: 13 Post(s)
I get power to glow plug, lights, radio and 12V to the battery, I tried to place a screw driver between the selenoid and the starter to see if the starter would turn over but nothing. Seem to get 12V to the relays. Still nothing when I turn the key to start
Bev is offline
post #6 of 24 (permalink) Old 01-08-2014, 05:11 PM
TimmahW123's Avatar
Quoted: 30 Post(s)
Ok the battery is putting out 12V but when you turn the key to RUN does it drop or stay the same?
Tim
Current Rides
post #7 of 24 (permalink) Old 01-08-2014, 05:28 PM Thread Starter
Bev
Quoted: 13 Post(s)
Stays 12V
Bev is offline
post #8 of 24 (permalink) Old 01-08-2014, 05:36 PM
TimmahW123's Avatar
Quoted: 30 Post(s)
This happened to me about 2 weeks ago and cleaning the battery terminals did it for me. But it may not be in your case. Can you try jumping 12v directly to the starter?
Tim
Current Rides
post #9 of 24 (permalink) Old 01-08-2014, 08:37 PM
Date registered: Jul 2008
Quoted: 348 Post(s)
If you put a wire directly from the battery to the solenoid, and it doesn't start...I would say the issue would be with the starter. Your ground cables may also be an issue, the transmission to the chassis and the battery to the chassis are the main grounds. You can also attempt to smack the starter with a hammer to get it to go again...
cooljjay is offline
post #10 of 24 (permalink) Old 01-08-2014, 08:39 PM
Date registered: Mar 2008
Vehicle: 1984 300D
Quoted: 73 Post(s)
That happend to Me. The Engine started fine when I left to go to a Realatives House. Started when I left the House.
I stopped to get something to eat and went to start and got nothing.
I had Multimeter in the Car and the Battery has 12 Volts.
I got a piece of Wire to Juper the Starter at the Solenoid and it only produced a tiny spark. I tried the Wire over the Battery Terminals and still only a tiny Spark.
I figured the Battery had some internal damages and walked a crossed the Street and bought another Battery.
With the new Battery the Engine started normally.
300Dman is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
