A/C help, condensor fan not turning - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 06-23-2013, 09:07 PM Thread Starter
Cyberbach's Avatar
Date registered: Sep 2005
Vehicle: 1995 E300D
Quoted: 2 Post(s)
Noticed the vent temp wasn't as cold as it should be now that the temp is rising, added some R12 and the fan on the front doesn't kick in when the compressor is turning. The A/C didn't seem to get very cold until after I finished filling it and drove it at highway speeds. Is there a relay for the fan that kicks on at certain temps or is it set to engage when the a/c is engaged?
1981 240D---234K - They said she was too far gone to be brought back ......... she lives!!! http://www.benzworld.org/forums/w123...completed.html
1983 300TD--103K
1995 E300D--162K
Yea these cars will last a million miles but what with terrorists, natural disasters and the H1N1 swine flu pandemic... God help us there's anyone left here to drive them.
Cyberbach is offline
post #2 of 19 (permalink) Old 06-23-2013, 10:27 PM
frans-c's Avatar
Vehicle: 2000 W202 Mercedes-Benz C250 Turbodiesel
Quoted: 22 Post(s)
It's activated by a pressure switch on the a/c drier. You'll need to excavate the system if you want to replace the switch.
Alternatively, and this is what I did, is to connect a relay to the fan (have you actually checked that the fan is working?) which is activated by the compressor's wire.
F R A N S
2000 Mercedes-Benz C250 Turbodiesel
frans-c is offline
post #3 of 19 (permalink) Old 06-23-2013, 10:43 PM Thread Starter
Cyberbach's Avatar
Vehicle: 1995 E300D
Quoted: 2 Post(s)
I haven't really had a chance to check the integrity of the fan yet frans, I just noticed it wasn't turning when filling it with R12, is there a quick way to short a relay to check it?
1983 300TD--103K
1995 E300D--162K
post #4 of 19 (permalink) Old 06-23-2013, 10:49 PM
frans-c's Avatar
Quoted: 22 Post(s)
Just unplug the fan from the main wiring harness and connect it with a few feet of wire to the battery. My bet is a faulty fan; not the pressure switch.
F R A N S
frans-c is offline
post #5 of 19 (permalink) Old 06-23-2013, 11:28 PM Thread Starter
Cyberbach's Avatar
Vehicle: 1995 E300D
Quoted: 2 Post(s)
I hope it IS the fan frans as I have my daughters 81 in my garage waiting to be salvaged and it had working A/C so I could easily swap out.
What size of relay did you use in case I have a pressure switch issue?
1983 300TD--103K
1995 E300D--162K
post #6 of 19 (permalink) Old 06-23-2013, 11:39 PM
frans-c's Avatar
Quoted: 22 Post(s)
Just a regular 30 Amp SPDT (5-pin) relay - shouldn't cost more than three bucks, or so.
F R A N S
frans-c is offline
post #7 of 19 (permalink) Old 06-23-2013, 11:59 PM Thread Starter
Cyberbach's Avatar
Vehicle: 1995 E300D
Quoted: 2 Post(s)
cool, didn't know to go with a double or single throw, I usually err on the double throw and 30 amp sure seems safe enough. Thanks again frans.
1983 300TD--103K
1995 E300D--162K
post #8 of 19 (permalink) Old 06-24-2013, 06:36 AM
ichris93's Avatar
Date registered: Jun 2013
Vehicle: 2005 C240
Quoted: 13 Post(s)
I thought the fan only came on at a certain temperature. At least that is my experience with the system. The relay for the fan is right next to the relay for the compressor.
ichris93 is offline
post #9 of 19 (permalink) Old 06-24-2013, 09:54 AM
frans-c's Avatar
Quoted: 22 Post(s)
Seeing as the fan is pressure-switch activated, I doubt temperature has anything to do with it.
If the fan checks out with direct 12 volts, I think you may want to check out the fan's relay before excavating the system to replace the pressure switch.
F R A N S
frans-c is offline
post #10 of 19 (permalink) Old 06-24-2013, 10:11 AM
ichris93's Avatar
Vehicle: 2005 C240
Quoted: 13 Post(s)
On a 1982 240D, which is what I have, the aux fan temperature controlled. At 144F it comes on. A/C help, condensor fan not turning-imageuploadedbyag-free1372090158.252265.jpg
Originally Posted by DSXMachina View Post
You're kind of a compromise. You drive, you break down, then you take it apart.
ichris93 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
