HELP!! W123 euro M110 280E, Supercharging advice needed!! - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W123 E,CE,D,CD,TD,TE Class
Old 12-30-2012, 04:34 PM   #1 (permalink)
Frank-cj421's Avatar
Vehicle: jeep cj6 using unimog421 running gear, 1972 450sl, 1983 280g, 1988 560sec, 2002 ml500.
Send a message via MSN to Frank-cj421
Post HELP!! W123 euro M110 280E, Supercharging advice needed!!
Hello all,
I'm looking for some help an advice from anyone who has supercharged a M110, 9:1CR euro engine.
Right then, for the purposes of this question, treat me like an idiot (not hard I know...).
I'm looking for an idiots guide to supercharging.
I've got an Eaton M62 (I think), from a Merc CLK230 Kompressor, for my Merc (keep it in the family an all that).
I don't want to run big boost, I'm looking for around 8-10psi to start with, does that sound like a safe level to run?
A few details of my engine, etc..,
It's a Mercedes M110, 6 cylinder, capacity 2746cc, max rpm 6500.
I'm going to use an intercooler, and I've got a little piggy back ecu to run 2 extra injectors in the air intake to take care of fuelling issues from the Bosch mechanical injection system.
My first question to start with, how do I work out what pulley sizes/ratio I need?
Cheers Frank.
Frank-cj421 is offline   Reply With Quote
Old 12-30-2012, 08:40 PM   #2 (permalink)
PlaneCrazy's Avatar
Date registered: Oct 2010
Vehicle: '82 W123 240D, OM617 non-turbo, bastard 5-speed; '95 W202 C250 Diesel, OM605 non-turbo, 5-spd man
What is the volumetric flow rate per revolution of the supercharger?
Donkey, decision pending
W202 C250 Diesel
PlaneCrazy - it's more than a name, it's a life choice!
QUOTES FROM CONSTERNATIUS:
"Inside every small problem is a big problem screaming to get out."
PlaneCrazy is offline   Reply With Quote
Old 12-31-2012, 01:48 AM   #3 (permalink)
Hi PlaneCrazy,
It's 1.015litres(62 cu in).
Old 12-31-2012, 01:22 PM   #4 (permalink)
PlaneCrazy's Avatar
Originally Posted by Frank-cj421 View Post
Hi PlaneCrazy,
I'm not promising it'll be quick, but I'll do a calculation for you.
Old 01-01-2013, 11:29 PM   #5 (permalink)
PlaneCrazy's Avatar
In the mean time, here's someone who seems to have a similar idea to yours...
Old 01-02-2013, 10:37 AM   #6 (permalink)
Stretch's Avatar
Date registered: Jul 2011
Vehicle: 1981 300D non turbo
Google says
Supercharger Information and Formulae
1981 300D (non turbo) 123.130
Project car - stripped to the bone
Stretch is offline   Reply With Quote
Old 01-02-2013, 10:05 PM   #7 (permalink)
PlaneCrazy's Avatar
I went to that site as well, but couldn't understand it.
I prefer to do these things from first principles, but the site I linked to didn't mention anything about power gains; however, he did a bit of work on boost vs. drive ratio.
Old 01-02-2013, 10:12 PM   #8 (permalink)
That's really the info I need, using that info, I'm going to make a few crank pulleys, and start with a smaller 1 than I want, and then go from there.
I think it's better to start at a lower boost than I want, and go from there, it's better to be safe than sorry.
Old 01-03-2013, 12:38 AM   #9 (permalink)
Stretch's Avatar
You have to over fuel it though don't you? Even with a small boost it will be too lean. How are you going to tackle that?
Old 01-03-2013, 01:15 AM   #10 (permalink)
I'm fitting 2 injectors in the air inlet, just before the metering flap, these are controlled by an ERL MF2 injector driver.
This works by taking an rpm signal, and a boost pressure signal, once it's been set up, it uses these 2 signals to determine the extra fuel require, then activates the extra injectors to suit.
The good thing about this is, it only works when there is boost pressure present, so I can use the supercharger's electric clutch pulley, to switch it of during normal driving.
So, in theory I will have the best of both, when using the car on the road I can simply switch off the supercharger, and drive he car as standard, then when I go to the track, or when the mood tes me, I can flip the switch, and let the supercharger come and play!!
Bookmarks
